Leaked DL30 Froyo Build Available NOW! (Includes Full Instructions: Updated 2/5)
Status
Not open for further replies.
I'm not sure if it's an "issue" Cory, but the option to "Stay Awake" while charging is missing from the Development Menu in Applications. Only workaround is to download an app from the Market to turn on/off the Stay Awake feature.
welome to android central.... no you dont need to be rooted,,,,and yes when you apply DL30 you will be rooted, just follow the directions:)
Sweet looks like I am having frozen yogurt during the Super Bowl!! Everyone is talking about Titanium Backup but is MyBackup Pro just as good?
Hmmm... What happens if you select one of your contacts that is both a Facebook contact and a Google Contact, open it up and then unlink the 2? Does one of them have a picture now? That might explain something, and point to a bug.
If you don't see anything interesting there, I would:
1) Delete the Facebook account.
2) Go into settings > accounts and sync > select your Google account > uncheck Sync Contacts.
3) Download Contact Remover from the Market.
If the following step makes you nervous, you can export your contacts to your SD card via the Contacts app. I have done the following before myself, without loss of contacts.
4) Open Contact Remover and Select All (Your Google Contacts will still be listed).
5) Go back into settings and reselect Sync Contacts in your Google account.
6) Wait until all contacts have finished syncing.
Do they have pics?
7) If yes, open Contacts.
8) Click the menu capacitive button.
9) Click more then click Get friends.
10) Choose Add Account and finish from there.
Have pictures for everyone else now?
The integrated Facebook app is not known for it's ability to work well when it comes to syncing. For reliable picture syncing, I recommend an app called syncmypix. It's free and works well.
Reactions: curve014
I am stuck in airplane mode can't make calls or texts! my baseband version is unknown, my hardware version is unknown, my phone number is unknown, min unknown, prl unknown, eri unknown, meid unknown, network unknown, signal strength 0dbm, mobile network type unknown, service state radio off, roaming not roaming, mobile network state disconnected! I have no idea how this happened my phone was working earlier today and all of a sudden poof! The only thing i did was delete the game gun bros and a folder on the sd card with an interrupted download of gun bros!
just tried a dalvik cache wipe still same problem. when the phone boots my signal strength bars indicator starts as a white circle with a slash through it then turns blue!
Installed this on my phone and I have the flash player installed but when I visit a site with flash it says I need to install the latest player and sometimes it crashes, any ideas why this is happening?
Sent from my SCH-I500
Hey guys, just a question:
First post says its safest to do this from a factory reseted device on DL09. However I flashed to the Supah Clean for DL09 that was posted a few weeks back... so if I want to go to this froyo ROM, do I need to go back to the original ROM that shipped with the phone or can I upgrade from the Supah Clean ROM that I am on to this froyo version?
Should be ok but , you should wipe data/cache......but it should only take a couple of minutes to flash stock with odin and do it cleanly
Reactions: mrboba
Cory your instructions were DEAD ON! pretty much a noob. 2.2.1 on my phone. First try.
Thanks!!!
dude, i spent hours on a diff site trying to follow their instructions. thanks so much for being so informative about it. really helped me.
Do they have pics?
Thanks! I really appreciate the help!
uh-oh...
when I select the sd card update.zip, I get a white traingle surrounding an exclamation point and the green droid standing under it.
help
Hit tge button again..in. Blue you hit home button to select..green and red use power button
uh-oh...
help
Sent from my SCH-I500 using Tapatalk
Reactions: russ29643
If your phone won't boot you're going to have to Odin an image on it to fix it, I suggest Odin'ing the stock DL09, rooting, then upgrading to DL30 with Cory's instructions.
Status
squirtman
