LG G2 Screen Protector
Hey TahoeRunner, the edge does not pose a problem, it was just something to point out, some people might not care, some might get annoyed, if you have a case that forms a lip around the front of the phone, then you'll be good. I chose to go with the SuperShieldz because I dropped my old S4 and cracked the screen protector on the corner, which I thought, it's better to buy a cheap protector, it was just something else for me to try. Figured if I have a decent case and something to protect the screen I'll be good. iloome makes really good protectors that's all I can say, but it was a no brainer for me between almost $20 for one or $5 for 6. You can spend $5 and try it, it's cheaper than almost $20 :D
Hi VTO.
Thanks for the update the other day.
I'm liking the Super Shieldz the more you talk about them
Are these the same shieldz you bought, and where did you buy yours from? Does the sizing fit the G2 pretty good?
Amazon.com: SUPERSHIELDZ- High Definition (HD) Clear Screen Protector For LG G2 + Lifetime Replacements Warranty [6-PACK] - Retail Packaging: Cell Phones & Accessories
Thanks again,
TahoeRunner
2:47am PST
02/18/2014
yes sir, that is the one. Good price, plenty protectors in the box and I like the way they look. wish I could post pics :(
Hi VTO.
Thanks again,
TahoeRunner
2:47am PST
02/18/2014
Bitterbuthappy
