Likes and Dislikes of Android Pie & One UI so far...
Nice , do you like it better then the note 9?
It's better in many ways...but as of now I love both the phones....Note 9 and mate 20 pro both are my daily drivers ...but personal phone is Note 9 and work phone mate 20 pro...pro is super fast...cameras are awesome...size is perfect...if u think of it both phones have same screen estate but Note 9 is way bigger...
If I had a choice to use only 1 phone i would chose mate 20 pro as I see it as complete package...battery life is 2 days in mate 20 pro
thanks for feedback guys on the mate pro , sounds like a great phone .
would like to try it but without warranty if something happens I just cant get it ..I'm in the US
found new bugs...Dolby atmos keeps switching off by itself...and music controls dont work on lock screen
Should i do clear cache thingy...
Can u guys help me how to clear cache
In pie you cant go in recovery anymore to clear cache, can do app by app long pressing them
Edit: you can I'm thinking of my other phone sorry
Restart phone hold volume up and power button same time take u in recovery clear cache
Thanx bro...will do that....
Have any of u found any bugs ?
Yeah device care , drops to zero alot and always try to connect when cleaning. I get a day and 7hrs screen time battery life but nothing like Oreo. I Kno it's beta so not too bad ,and volume seems lower then Oreo for some reason other then that it's been fine no app crashes or restarts.
Dark mode is working the way it should and animation you dont need to go into developer settings to toggle it as it's in accessibility .
I found the animation setting under accessibility and it is awesome! Highly recommend.
Wow what a step back, feels like EMUI this is super heavy skin with a lot of necessary space being wasted. I love how the word messages takes up half the screen 😂, what a epic failure.
I am using beta in my note 8. Liking the update but missing some. Not sure if it is beta issue. Can you guys confirm?
1) Lost all my quick commands with Bixby.
2) No Flipboard integration in Bixby
3) Bixby not working with WhatsApp
4) Dual Camera support
5) When opened multiple apps, following functionality is missing
- Create app pair
- Switch apps
You do realize that when you interact with it (e.g. scroll up) the content fills the whole screen, right?
As I have brought up in another thread or two, I do not like how I cannot toggle between recently opened apps when using the gestures (in the same way as when you double-tap recent apps when not using gestures). I hope maybe I'm just missing something here, because I'd like to give gestures a chance.
RangelS25
