Little problem here..
whitehorse84
118
3
well I installed font changer last night and loaded up some fonts..
it SEEMS like one of the fonts i flashed caused my evo to freeze after the prompt to "reboot"..
So I did a battery pull and rebooted as normal but it's been stuck on the white "htc EVO 4G" screen for a few minutes now and i tried booting into hboot (worked) and restart from there but I have the same problem.
I really would like to NOT loose everything on this setup (running CM6).. do I need to resort back to an old nandroid backup? :(
SmokeCrawler
1,298
189
This is a suggestion but maybe you can hook your phone to your computer so you can view your SD card. Go into .fontchanger folder and remove that font.
If that don't work then you might have to restore a backup.
Reactions: whitehorse84
SmokeCrawler
1,298
189
I also use font changer and that is how it was by default. You know where the fonts go when you install them?
Just curious in case it should happen to me:)
whitehorse84
118
3
not sure, I already did a restore from a couple of days ago .. everything's back up and running :)
*remember kiddies, when in doubt.. nandroid!"
I think this problem was because the font I flashed was one that font changer wasn't able to give me a preview of..
damn.
