love francos kernel
Just flashed 18.1. Ever since issues with the 16's I've done a cache/dalvik wipe before installing. I'd rather not take any chances, nah mean.
I've kept my min at 350 and max at 1200. I've used the 1500, 1600, and 1650 just for fun and they run very smoothly, where 1500 used to be horribly slow. I received the following results using Quadrant:
1200: 2700
1350: 2495
1500: 3141
1600: 3187
1650: 3279
Just had SOD. Franco just said on XDA he's aware of the issue and will be releasing an update within the hour.
Also, check out his recommended settings for the colors. Screen looks amazing--much much much better whites.
What is an SOD? and where is his recommended colors?
SOD = sleep/screen of death. Essentially the phone won't turn on (all black) without a battery pull. 18.1/.2 were riddled with them.
His recommended colors are in his app under settings. They are: 143/158/194 (Red/Green/Blue) and for Gamma -8/0/10. Go to Color Multipliers for the first set, then in Settings tap on the individual colors to adjust gamma. It's the closest thing to Voodoo Colors we've got (so far). White looks great now!
Reactions: Nechasin
For what it is worth, I never had any issues with sod. I've been running 18.1/2 since they came out.
Me neither until 1 this afternoon. Was running 18.1 then, so who knows? I just know a lot of folks reported it so he tweaked something that was in the previous base/stock kernel. People also reported higher than normal temps, which I was experiencing firsthand.
Interesting. Take some blue off with the multiplier? My blue was reduced, and while I guess it's sorta kinda there, it's not nearly as apparent as before.
Yes, 18.4 was out because he had to remove the 1.6 and 1.65 settings. Those settings + people flashing while overclocked w those settings caused a loooooad of reboots and loops.
Running 700-1500, conservative w hot plug enabled.
Hope 18.4 plays good with my phone, had to go back to 18 after flashing 18.2 bacause I kept getting rebooted for some reason.
handsome
