LS670ZVJ Update Coming 4/4
I can't upgrade to the zvj fimware. Since my SD card umoute. My card don't work. Please help me!
Thank you!
Thanks folks. Just installed update.zip on stock recovery from ZVD, worked perfect, now I'm ZVJ. Hopefully it's good gingerbread this time and not crapola like last time!
Let us know how it works, and if there are any bugs! :)
so far so good hydroRom flashed without a problem,data,radio working,wifi,bluetooth working,also i noticed that my radioversion reverted to zvh,im going to check it out thru terminal emulator
i think tht all the build prop from hydro rom replaced the version and that im still running vj
Installed ZVJ using the ZVD recovery. No problem but I'm experiencing the touch issues that ZVH had. I'm going to jump back to ZVD until I get more feedback or the kernels and rooting methods get straightened out.
ok so let me get this straight... if you are already on ZVJ... can you root??? or do you have to root...then UPGRADE to ZVJ... because i am ALREADY running ZVJ.. got my update though cell carrier.... sorry if i am a little lost... Do i need to download the Zvj update to root if im already on ZVJ?? Just seems a little confusing.. for those of us already running ZVJ
There we go! ZVJ rooted no problem following the rooting guide mentioned above. Don't be downloading the ZVH update - the entire process uses the ZVJ update.zip - replace ZVJ for ZVH in that entire thread. Download ZVJ update.zip. Install the VH recovery. Follow the steps thereafter using the ZVJ update.zip file. Make sure you are already rooted as well!
ou already running ZV
were you already running ZVJ when you did this???
If your allready running ZVJ, you will need to revert back to ZVH or ZVD first and root it. Then follow the guide by sfhub that I linked to. Only difference is step 4. You will flash ZVJ instead of ZVH there.
I have ZVH non-root... Waiting for ZVJ update.. Nothing.
Geez! Come on!
Update.zip for zvj is already uploaded here ! No need to wait any longer.
Edit :
Just to throw my piece in, I also updated and rooted following the mentioned method with no issues. So far every thing is pretty good in my book. Sdcard works no problem and none of the double taps for me.
Reactions: PatrickAkridge
I'm having the double tapping too...gonna root in a bit and try drew's kernel.
For those having sd card problems, what sd card are you using? My husband is going to get me a bigger card friday and I don't wanna get one that's gonna keep unmounting...
Edit :
Updated and rooted using the instructions, installed HydroRom, everything seems to be working fine. I have 3g, phone service, etc etc.
I was using the CM7 ZVD on here, which I liked, but it was getting really crashy so I decided it was time to try a different rom.
Can't wait to apply upgrade to zhj firmware. My SDcard doesn't work due unmouting. It doesn't help. Please help me!
Thank you!
Kind of ridiculous that they didn't fix the double tapping issue even on the 2nd try. Don't really care either way since every custom rom here is far superior to stock rom anyway.
I'm experiencing touch issues as well. It registers some single taps as doubles.
Also, the performance isn't as good as on froyo. There are choppy animations almost everywhere (solved by turning off animations, but who wants to do that?)
However since there were good reports of improved performance, it may just be my phone because its a lemon (reboots randomly no matter what rom/radio I was running).
jojomojo
