LTE doesn't work in a spot it always works
  • Start date Start date
A
Android Central Question
I turned off my phone and when I turned it back on it said I had no sim card so I turned it off again and once I turned it back on again it showed I had a sim card but now there's no LTE or any kind of data I can use so like someone help
Welcome to Android Central! Which phone? Try powering off, removing the SIM and inserting it again, then powering back on.
Hey, go to settings and then at network settings you Will see something like mobile network Check if you have LTE On at network type, if doenst appear to you the mobile network thing, your sim card is not even assumed by your Phone.If you cant change it to all types of network your Phone needs to be repaired.
If what B. Diddy suggested doesn't fix it, bring the phone into your carrier - the SIM could have gone bad (and they should replace it).
