[MAC METHOD] Root,Unroot & Unlock Your VZ Galaxy Nexus
you renamed the recovery file "recovery.img" correct?
if so, try it this way
./fastboot boot recovery.img
if not, rename the file "recovery.img" instead of recovery-5.8.whatever-toro.img
then do it like this:
./fastboot boot recovery recovery.img
it just keeps telling me that it 'is a directory' doesn't do anything to my phone. i'm starting to go a little insane
just to be clear here. the folder you downloaded from the OP is on the desktop. you have renamed this folder 'adb-fastboot'
You have successfully unlocked the bootloader (it now shows an unlock when you boot on your device normally).
And your phone is in fastboot/bootloader mode when you enter the commands you need.
I ask because all the files you need are in that folder, and it should work.
It sounds like you might not have unlocked the bootloader. Or something's out of place.
Reactions: pat0neill
OK I got a go but here's what I think you should do. Reboot phone by using volume keys to power off. Then restart your CPU. Then try again following either the directions in op or the recovery method I typed up.
You have what you need but not sure why its not working. If you can't get it.going I'll be back tomorrow morning but I gotta go to the girls house and she's impatient .
Gl
a few pages back theres a one click for mac. i cant search for ya but there is a one click for mac listed in a post in this thread you can try
i'll be on tomorrow and we'll work it out tho in the morning or early afternoon
kkk this im trying to root my phones in unlock so im stuck and this dudes videos are just tweaked the out dam bro just make i simple u keep going back and forth to diffrent
I'm rooted, but how do I know if my bootloader is unlocked? I want to flash a rom, but bootloader must be unlocked to do that correct? I also need to know how to flash a rom using a mac.. please help
Where are you stuck? Give some details we'll get ya sorted out.
If youre rooted you must have an unlocked boot.
Is there an open lock on the Google screen when u turn the phone on?
For roms, see cyber warriors guide stickied I'm this forum. Very thorough and straight forward. Any questions please feel free to ask
does this method only apply to 4.02? or would the su404 link posted in earlier post make this compatible to 4.04 also?
I followed the steps, unlocked bootloader successfully, thought root was completed as I have superuser installed but... rom manager wont allow me to flash recovery and titanium backup says, "Sorry I could not acquire root privileges."
please help.
please help.
yeah replace the old superuser zip with the su that works with 404:
http://dl.dropbox.com/u/25213603/su-latest-404.zip
that should do the trick
btw sorry i didnt see your post sooner.
kolorado
