Manually Update to LG8 unrooted phones only.
Mine does same thing here...
I exported the file from dropbox to extsdcard
And went into ASTRO to verify it was there, but when I go into recovery it says cant mount sdcard.
Posted from my Sprint White GS3 via Tapatalk
Is your phones sd card formatted with fat32? If not, you need to format to fat32.
________________
Just Flash It !!!
Re: Manually Update to GL8 unrooted phones only.
Yea it not gonna come with one when u have a 16 or 32 GB phone u have to buy that on your own time
iTz Young Amazed
ah ok, i thought i got gypped. Thanks! Update worked like a charm once i found a microsd lying around. Great to have brightness slider finally. For some reason it turned off "packet data" so i had to turn that back on to use 3g. Thanks guys.
Did the manual update last night and it works flawlessly. Had to restore universal search again but no big deal there. Incredible signal improvement here in Dallas area. :thumbup:
New 3g speeds after update done :D
Download the following update zip and place it on your external sd. Go to settings/security and make sure unknown sources is unchecked.
Shut off phone. Press volume up, power and home button at the same time. As soon as you see a flash, let go of the buttons. This will put you in stock recovery. Using the volume bar to select and power button to activate, select update from sd card. Choose the file you previously put there. Push your power button. Your update will begin.
This is only for those with STOCK unrooted phones with STOCK recovery.
http://db.tt/E1act5CK
Edit: Changed internal sd card to external...
_______________
Just Flash It !!!
fyi buddy its LG8 not GL8; may want to fix the thread title
Reactions: Skunkape60
after the update it seems that options for choosing a different type of network is gone. I have at home dual band router and I did setup by default to using 5Ghz networks. Now I'm at place where they offer free wi-fi, but I can't find the network because is not a 5Ghz one. Then I try to switch to 2.4 or Auto but under wi-fi settings I don't have that optiond anymore.
Can anybody check and see if you guys have that options after LG8 update?
Thanks
What's stock recovery? Do all s3 have it built in
Unless you have rooted your phone and changed the recovery you have the stock recovery.
To get into stock recovery, press and hold volume up, power and the home button at the same time. Watch the screen and when you see a flash, release the buttons. Your phone will boot into recovery.
_______________
Just Flash It !!!
_______________
Just Flash It !!!
OK thx
Got mine up and running! Many thanks because I was growing quite impatient on the ota
I unzipped the file but after that how do i find it to pyt it on sd card
This IS a sprint forum, and Yes it is for Sprint only. This is the update currently being pushed ota by Sprint.
So if you haven't purchased additional storage card, no way to do this?
Correct. I would highly recommend you getting a micro sd card. I use mine to put all my pictures and music. The nice thing about this phone is that unlike previous phones, we get to use all of the internal storage for apps, unlike before where we only got 1 or 2 GB of core app storage with the rest being moved to a sd card if present. That just slows game loading times down since the internal memory is always faster than an sd card. Also, with cheaper sd cards it would lead to apps getting corrupted. We now can use the internal storage for games and other apps exclusively. The camera app is even nice enough to ask if we want to store our pics on the sd card....all around, a huge improvement.
Reactions: trunkmonkey1972
Maxyguy666
