[MEGATHREAD] LG IMS Keeps Stopping (5/2022)
Skywolve
7
So I know there was one post already related to this but no solution in that thread has worked, nor has any solution posted on various websites.
I wish I could just disable LG IMS as the frame work contributes to features of my phone I simply don't use, however I cannot find the place to do so nor the IP type most websites tell me to. Like I said I have a Stylo 4 so that may be the issue.
I also doubt it has to do with any particular app as a factory reset did not fix it.
I am at my wits end so either a detailed guide for disabling it or any other fixes would be greatly appreciated.
I have an Aristo 4plus and have been getting this pop-up all day as well
I tried the: apps/notifications - App info - three dots - show system - com-lge-ims-rcs-provider - storage - clear data "fix"
And It is still happening. Is there something I missed?? Edit: I am on Metro pcs T mobile as well
I logged into my T-mobile account and went to the support area known as "Community". One person, about an hour ago, indicated they had contacted Tmobile Help on Twitter and the response from TM was that they did not know when the issue would be fixed, but LG is aware of the issue and is working to get it fixed asap.
Update: another TM user in "Community" indicated the same info/status as the above.
Someone mentioned that as well, fyi
stoffe949
