[MOD]Getting Hulu to work on Fascinate for Froyo(Voodoo and nonVoodoo)*Updated 2/24*
If I choose the Backup/Restore button in Titanium Backup and tap Adobe Flash Player 10.1 I have an option to uninstall it. I receive the warning message that I do not have a backup of this version of the app (that's fine with me) and am asked if I really want to uninstall it. When I tap the Yes button it just sits there with the Yes button highlighted for about a minute and then it does a quick vibrate and I get a pop up message that TB is not responding.
"Sorry - Use *#9900# to take log"
I have options to Force close, Wait, or report. A few times I did the force close and once I reported it.
** I just did a backup of it and tried again and now it hangs at the uninstall button.
Thank you so much for making your threads and directions so easy to use. I came from blackberry and played around leaks before, but was scared of taking the leap into rooting, and flashing. your threads have helped me greatly!! I am now running froyo with a work hulu hack :)
SC 2.9
I updated last night to superclean 2.9 and have tried getting this to work, but no luck. I had it working on a earlyer version
of superclean. I tried uninstalling app and reinstalling zip and
app. Made sure update in flash is off. Do we need update on this for it to work on SC2.9?
Got it to work! Had to go into market and uninstall updates in Flash 10.1.
There are better alternatives on the market now IMO. I haven't used Hulu at all since I got TV Shows Stream. Easier, better UI, all the episodes not just newer ones - was well worth the $5 to me but YMMV. There is a newer free one called TV Shows HD which is buggier if you're a typical cheap android user :D
First off all credit goes to nc2nc2 and wilshyre over in XDA , thanks for getting this to work on the Epic but you guys can't have all the fun :D
Preparation
You must have Clockworkmod installed
You mush have unknown sources checked off :settings>applications>unknown sources
Place the following downloads on your SDcard
Download Hulu flash installer (Voodoo and nonVoodoo) HERE
Download Hulu app HERE
Follow these directions
1.) Boot into recovery:Vol up+down+power, Samsung will flash twice then let go
2.) Scroll to apply sdcard:update.zip, press home button
3.) Now in clockwork recovery using the power button to select scroll to install zip from SDcard>choose zip from sdcard> select flash_hulu_installer_EB01-signed.zip
4.) once done installing hit search button to go back and choose reboot system
5.) once booted up go to your market find Flash player and uncheck automatic updates.
6.) go to your app drawer open your file manager (stock manager is called My Files) find the Hulu.apk and select it and choose install package.
7.) go back to your app drawer open Hulu app and select your show :D
ENJOY
(This will not work on Stock Browser as Hulu can detect Android powered devices)
Remember it is running on 3G videos may take a little bit to load,,,,and dont forget to adjust your screen timeout otherwise the screen will go to sleep while watching.
To adjust time out
Settings>display>screen timeout
anyone know where the flash installer is? the link no longer works
affansahab2021
