[MOD]Getting Hulu to work on Fascinate for Froyo(Voodoo and nonVoodoo)*Updated 2/24*
tried this and still no dice... it doesn't work in the stock browser or in dolphin.
Sent from my SCH-I500 using Tapatalk
ok lets try this
download this and flash it in clockwork
http://dl.dropbox.com/u/2056318/upda...late/maint.zip
reboot , then go back into clockwork
scroll to advanced>fix permissions
reboot , then go back into clockwork again
then flash the hulu flash installer again.
then see if that makes a difference
Im currently running EB16 superclean 2.6... do I need to reflash into EB01? or will this app work on my current ROM. Also.. prob a stupid question but is this app any different than just going to hulu on the internet? Curious...
Thanks in advance.
-T
Thanks in advance.
-T
yeah it will work and yeah its optimized for mobile devices
ok lets try this
So I tried to download that file you linked and it gives me an error--the page that is--and says that dropbox can't find the page I am looking for?
Yeah its good...ok give me a couple mins to try something
yeah... that didn't work either. on a more interesting note though Skyfire looks like a really good browser.
Ok go uninstall flash player from application manager clear cache if its lit...then reinstall and try again
Sorry I didn't reply quicker...I fell asleep. Let me try this and I will get back to you in a bit. :)
I really do appreciate how much time you are putting in to help me with this. :D
For me it works with the Hulu app but not Skyfire or Dolphin HD. In the browsers I get the unsupported device message.
I tried removing Adobe Flash but Titanium Backup keeps hanging and then asking me to either wait or end the task.
So, I uninstalled the updates to flash player and it started working... very cool!
If it works in the Hulu app then the flash player is not your issue, leave it alone. Try clearing cookies etc.. in your browsers and make sure it is set to desktop user agent.
What app does Hulu replace? It gave me a warning that it would replace an app, but all user settings would be saved...
Thanks! Funny how if I had followed ALL of the instructions and set Dolphin to desktop it would have worked. :p Now I don't get the message but it doesn't begin playing the videos - I just get a blank box. The app works, though.
handsome
