Myn RLS 2 is out!
Hey guys I was wondering how do I set up the Swype to the Rom after i have the ROM up and running?
Kinda tricky but heres how.
1 - download the theme
2- download and install metamorph from the market.
3- uncheck swype in your keyboard option screen thing in the settings
4- Go into manage apps in your settings, and clear data and force stop.
5- go into metamorph, find and install the theme from your sd card
6- turn swype back on in your settings and stuff.
7- your all set.
BUT YOU WILL HAVE TO DO THIS SAME RITUAL EVERY TIME YOU REBOOT YOUR PHONE.
Thats the catch, or rather the glitch.
i need help with my mms, i am UNABLE to send mms no matter what i do, the connection settings are grayed out, what can i do?
Does this look right to you?
it gives me a generic error, can u post your mms settings screen?
im also having big issues now with connectivity and data speeds again, its pissing me off, so im switching to kings 11 to see if anything changes, i just disabled battery tweak and am loading the kernel as we speak.
I would but I just restored cm6 haha.
Nightlys are what's up, there's power control in the pull down bar now :D
Now on RLS2 from the original Warm and am loving it....especially the LP option that I am taking full advantage of. Most everything is working as it should but I have experienced one glitch (may have been mentioned before). When I use one of the native alarm apps, the alarm will sound but there is no way to dismiss it without doing a reboot or pulling the battery. Any work-around for this?
Now on RLS2 from the original Warm and am loving it....especially the LP option that I am taking full advantage of. Most everything is working as it should but I have experienced one glitch (may have been mentioned before). When I use one of the native alarm apps, the alarm will sound but there is no way to dismiss it without doing a reboot or pulling the battery. Any work around for this?
I dont have this issue... I use the Alarm Every morning...
are you sure its not just the sound you're using? :confused:
Anyone else having a problem with video playback? All my videos play fine on my pc but lock up when played on the phone.
First thoughts is that kings#11 is a little more choppy and sluggish, but battery life seems better so far then I was getting before with the battery tweak and stock kernel.
From my HTC EVO using Tapatalk pro.
It can get real bogged down when doing a few things and getting a text, stuff like that, anyone else experience this?
I may be going back to stock kernel and tweak.
With the battery tweak my battery lasted bout 8 hours today but that was with having 4g on by mistake all day when I want in a 4g area all day pretty imperative
sent from my HTC Evo using tapatalk pro
Mines not fairing so well either, once I got on the phone, my battery dropped like a rock, add a hour onto that time cuse I rebooted.
It's just the bottom look cooler to me I like it how look..
and using stock kernal
Myn has pretty much finished working on that look for sense
and you can select which apps you want to be in (and in which location) in the rosie (phone - mail - web - text - what have you)
this ROM is way cool
jipeve
