Myn RLS 2 is out!
Mines not fairing so well either, once I got on the phone, my battery dropped like a rock, add a hour onto that time cuse I rebooted.
From my HTC EVO using Tapatalk pro.
I noticed the same thing. I'm running the kernel that came with the ROM, and the battery tweak, and when I'm on the phone it drops REALLY fast. When the screen is off it sips the juice, though.
I gave up on kings 11, its draining really fast when I'm hardly using the phone and it seems sluggish.
Back to stock kernel for me and battery tweak.
What preset are you using?
i just re loaded battery tweak and im using option #2 again.
Well... I've been usbless for over a week now. Can't take this anymore... I need to flash something!!! I need a fix.. haha.. Gonna dl this and try it out finally
Btw... VaelPak 2.2 with Netarchy 4.1.9 gave me 18 hours of battery with 7 1/2 hours of awake time (including plenty of Angry Birds). Lets see if this "battery tweak" can match that..
Well, it was a fun ride. I'm already back to CM6 though. Battery life just wasn't where I wanted it to be.
I have it as a fashionable back up though, especially when I need 4G.
Ok, Flashed this last night. Unplugged this morning at 7am it is barely 8:30 and I am down to 88% with minimal use on phone, no texting and no internet. I was having much better luck with Baked Snack 1.8. What kernel are you guys using? How to I configure the battery? I am running Set CPU.
The Thread for the battery tweak says dont use SETCPU at all...
It screws with what the Tweak does and drains battery...
did you read it before flashing? The Batt Configuration options are listed in that thread...
Reactions: EvoRoy
Ok, deleting Set CPU now. Will read Batt Config options today after work. I must have gotten confused I did read not to install Set CPU but was thinking it was for a different ROM I was also considering.
Thanks.
Dumb noob question of the day.....what is easiest way to access terminal? Flashed battery tweak last night and want to change presets. Thanks.
download terminal app from the market. Start it up you will have I think a flashing $ sign then type SU then enter and I think you will have a # sign, then type in batt_cfg enter.
Reactions: bassmanxu
you also have to flash the battery tweak separately.
i wish myn would say that in bold print, because alot of ppl just think its built in.
Thanks. Had the emulator but was forgetting to type SU to grant the access.
Hows it holding up for everyone?
I'm thinking I made a mistake with kings 11, I just flashed the kernel and never un installed batt tweak, so maybe that's why battery drain was bad because I forgot to uninstall it.
Im almost dead... I forgot to turn 4G off like a n00b -___-
Im at 28% unplugged at 7:30am
8 Hr's unplugged it says
Android system is taking up about 96% of my battery Im figuring it a rogue app I fired up ATK and killed everything
I was getting better life with it installed IDK why goes against theory
I was getting horrible battery life with kings 9-11. I tried Baked #5 and it was okay but so far I'm on toastmod 4.1.9.1 and so far it's been really good.
In the last 20 Minutes I dropped another 4% :(
I need my charger WHY DID I FORGET IT!!!!!!!!
Are you using the stable build of the kernel or the beta? Thx
I think I'm using the beta of the netarchy kernel. The less aggressive undervolting one.
krechbkk
