need help
SuperWario89
63
Hey everyone
i was using the evolved rom, was having some issues so i decided i was going to do a factory reset and then flash something new. Under the factory reset options i picked the option to erase the sd card...
now when my phone restarts i cant do anything, it just shows the htc sense background, but i cant pull down the notification bar or anything else like that. cant pick up phone calls etc..
i went into recovery (newest version of clockworkmod) and i tried to format/mount the sd card and it just keeps giving me an error... so i have no way of getting a file onto the card to reflash my phone..
any help?!
based on my searching, it looks like i have a soft brick... but i cant find an up to date tutorial on how to fix this
i looked at that already... my problem is that i cant install the android SDK because the java JDK doesn't have an installer for 32bit vista..
fml
looks like i was able to fix it by reformatting the card with my laptop, then putting it back into the phone and formating it there with clockworkmod recovery. rebooted the phone, did a partition of the sd card, and now i'm flashing the evolved rom again.
looks like i'm almost out of the woods!
i used an sdcard adapter and put the sdcard into my laptop. then i formatted the sdcard using my laptop. put the sdcard back into my phone, formated it again using the clockworkmod recovery. Then i plugged my phone into my computer, selected "mount usb" in clockworkmod, transfered the rom file onto the sd card, and then flashed like i normally would..
bantuanfintech
