Netflix for Optimus S -PROJECT ON HOLD
Re: Netflix flashable zips for Ath3nos CM and aospCMod for Sprint
From my earlier post:
Right now the option for drew's cm7 port is to use the ath3nos procedure. I will update to include drew's rom soon; although using the ath3nos zips wont hurt anything, they will display the incorrect info in 'about phone'. Hope this helps. Post if you have anymore questions.
Why was all the flashing necessary all i did was download the Netflix1.3Apk-Root from a Evo forum and it worked
I have explained this in detail in the last two pages. Pleader refer back for the answer to your question.
Lol. I hope to are it on our device soon enough. I'm actually considering cancelling the Netflix for hulu+ if they can get together a decent app that I can run on my phone. I will certainly include instructions as soon as its figured out! ;)
EDIT: Take it back. I have hulu app working on my phone now. Just waiting to get to a computer to type up the tutorial.
Ok got one last question . is there anyway this will work on Reborn Rom? Because i like that rom cause its smooth for me ??
I'll get into it if anyone still wants me to by the end of the week. :)
Well i would like you too .
If you would please . Cause i can only use the netflix with the green line uptop of screen which sucks
Sent from my Tapatalk
Okay. To get rid of the green line you will need to use a cm7 build... ie drew's cm7 port rom. The green line is normal in reborn rom. I don't believe it will be any different if you use this method. What version Netflix do you have right now? I think I read somewhere that the update does fix the green line but I'm having g trouble remembering where I read it and whether it was actually true or not.
Yeah. I'm pretty sure reborn is stuck with the green line unfortunately, no matter which way you do the process.
:/ aww only reason why i liked reborn cause i had full bars and on cm7 i get 2 .
That is a glitch in froyo. Your signal isn't actually better, it just appears that way. For all purposes, you could say that 2 bars on cm7=full bars on reborn. Trust me, don't worry about the signal strength. Its not actually better...
Re: Netflix for Optimus S now supporting all ROMs!!
Any feedback is appreciated! Hope you are enjoying. Bump for 7 downloads so far. Woot!
I got to run hulu and I was watching narruto with my son the other day really good I think you should go with hulu
Sent from my HTC Vision using Tapatalk
Why is this on hold for now?
I tried to install this this morning but Netflix would not show up in the app market. Any help with this?
Reread the first post. The very top of the post and the prerequisites are what you need to read. Simple as that. :) btw, I just figured all this out this morning. ;)
Was working previously, but now the movies won't load! I get an error message saying that there's a problem with your account, or Netflix has been deactivated on this device at Netflix.com. I've tried reinstating from titanium backup, but it didn't work. Installed the new version of Netflix as well, but I still got the same error. Using reborn rom 2.2.4. Anyone help? Want Netflix back on my optimus s
Edit: got it sorted now. I just repeated the process. Little green bar doesn't bother me too much. I'm curious about what cased this issue.
P.s. there's no green bar now!
Winnix
