New Firmware Pushed This Morning
Invalid Operation when trying to install update.zip
I am trying to install this ota update manually by putting the update.zip onto root of sd card then trying to apply it within recovery. I am on stock and am not rooted. When i select the apply update.zip on cd card option, i get a message saying invalid operation and my phone just reboots and nothing is updated. am I doing something wrong? I start by powering off my phone, then hold vol down + power to get into bootloader. I select recovery then i get to screen with red triangle and exclamation point. I hold power and vol up and it brings up with recovery screen where i get 4 options. i always choose the apply sd card option and it never works. please help. Thanks! I havent gotten the update ota yet and i keep trying to hit check for update. the popup comes up saying that is it checking for update but it then just disappears and nothing happens.
For those that have installed the update, does the leaked video version of skype still work?
Fyi, i'm in socal and i saw the update. Tried 3-4 times in 4g, 2x in 3g, finally, my 3g went to 1x on its own and the update showed up when on 1x.
When I hit check new, the Checking for update... box comes up for about 5 seconds, the disappears. Any advice?
I had actually got to the point where it started downloading this morning, then it would error out. Now I can't even get that far.
Not rooted.
How do you know if you got the update? I manually try to update but there is no update available.
Sent from my ADR6400L using Tapatalk
fistyjone
