This is why I'm not rooting the phone until the GB update. I figure once GB comes, there probably won't be anymore major updates.
Except Ice-cream Sandwich.
SMH How bitter sweet was that to type?
I just tried and got the "Service Unavailable.." and I'm in Southern Calif.
Checked for updates on Thunderbolt and had a 35.6Mb firmware pushed.
Updating now, will report back.
Come on guys. Pull the file so the community can use it...
Just connect your phone to the computer and copy the new "update.zip" file out of the cache after it's done downloading but before installing.
Update installed in SW FL. Sorry, I don't have a computer so I can't help out there.
Otherwise, installed quickly and without incident.
I just updated mine did anybody else notice that the battery and the cover both got bigger with this update?![]()
***DO NOT RESTORE IF YOU'RE STUCK IN A LOOP***
I'm on a rooted ThunderBolt, and I attempted to do the update, but the update failed. (Android character with exclamation mark (!) )
And was stuck on a loop--keeps says "Shutting down" each time I reboot into the Android operating system.
So, this is what I did to stop the "Shutting down" loop.
1) Once you are in ClockWorkMod Recovery, scroll down to "Wipe cache partition".
2) Select "Wipe cache partition" using the home key or power button.
3) Now, scroll down to "Yes - wipe cache".
4) Press the home key or power button to perform the wipe.
5) When done, restart your phone.
6) Your ThunderBolt will boot into the Android operating system and will say that the UPDATE FAILED.
7) Choose Cancel to stop the update.
8) Restart your phone one last time and you'll see that the "Powering Off" loop is gone.
Hope this helps!
Me too. Ditto. Except, I'm currently in West FLUpdate installed in SW FL. Sorry, I don't have a computer so I can't help out there.
