New Radio Rip 2.11.605.19 PG05IMG.zip
I have liquid smooth 3.2 as well. I'm of the theory that if it isn't broke, don't fix it. I downloaded the radio but I think I will hold off on the update for now.
Sent from my rooted Thunderbolt using Tapatalk 2.
Ok I finally remembered how to do it and now I have the same numbers, so far the wifi is amazingly fast. Will have to wait until I get into a 4G area and try it out. Thanks
Reactions: CEspaillat
Wifi works fine for me.
Looks like the radio is much more stable now.
Running Gingeritis 3D v1.2, should I update to this radio? Will I see much improvement? Will updating the radio effect the ROM (meaning factory reset)?
I have G3d and Updated the radio now all my calls are very fuzzy and crackly through the whole call
I believe this is only an aosp radio update. Gingeritis is a sense ROM. There is a different version for that ROM. Its nit universal.
I'm running BAMF 1.09. I flashed this radio two days after the OP posted it and it's working great. I have a hard time quantifying any improvement, ie. radio strength, but it hasn't hurt my reception in the least. It's stable and gives me a good connection to the cell tower since flashing it. I can say that it hasn't caused an increase in dropped calls. Instead, I feel like dropped calls in the mountain area where I live have decreased with this radio.
I am running G3d and also updated the radio. I find that I get better 4g and WiFi signals all around.
Sorry for the n00b questions, but flashing the radio didn't over write the ROM correct? I just don't want to have to re-install everything again.
Thanks!
Not able to flash this radio. I'm running BAMF 1.11 with the 3++ kernel. It's on the SD card, but won't flash. I redownloaded it and still no luck. I tried doing it through HBOOT and then tried it through ROM manager. Didn't work either time.
Any thoughts?
Thanks,
Lou
Make sure its on the root. Not in a folder. Boot onto bootloader. Should work from there.
O.K. The fifth time was the charm. I think my power button was sticking and moving me past the update option. Got it now. Will see how it does.
I flashed this radio last week. For me at least, this radio has given me about 2-5 dbm improvement in reception. I've flashed quite a few of the radios from MR2- MR4, and now this radio. Every time i do i make sure i'm at the same place in my house as a point of reference. All the other radios have been really close in data performance and call quality. This one however, seems to be just a little better in all aspects. But, from all the different threads and countless comments in all the forums about radios. I'm convinced that radio performance varies greatly from different areas, different phones, ROMS, and different people. Even though this radio kicks @!! for me it might suck for the next guy.
Reactions: jeffinchgo
taisiatetiana
