Nexus 4 Screenshots: Share them here!
Where did you find this theme? Can you provide any more details or a link? I want to create a theme based on this style but would like to know what some of the widgets are. Thanks! :)
I originally saw it on Mycolorscreen and then saw that the creator has his own site, Droidscreens. What this person did, Danut, was put everything into an app and put it on the play store. I'm pretty sure this screen is called "the seasons". To easily find it, go to Mycolorscreen and look under the "screen of the day" section and it's close to the top.
Thanks will check it out.
I tell ya, the day I found the My Color Screen site and more recently a few threads on XDA, I'm hooked! The only downfall is when things don't go as planned, it can be very frustrating.
I couldn't agree more :-)
Lock screen I made to compliment the above theme
Credits to blackbearblanc for the wall, icons, and custom slider.
The lock screen is the one I haven't tackled yet. I changed the wallpaper but I had to use multi picture live wallpaper in order to do it? I might have to head back to XDA to see how the lock screens are done.
One of my lockscreens
Got this. Everything is in my app drawer sorted into more tabs. Clean look but everything is easy to access.
Well .... Cant upload on nexus? Gives me an error of parameters
Sent from my Nexus 4
Here's what I came up with so far. Created the background in photoshop based on that design style. Still playing. I am going to make some custom icons tomorrow.
One thing I couldn't figure out is how to get different images for each screen. Is there a setting in Apex to do this?
No. It's an app called Multipicture live wall paper brother. I wish I knew how to use photoshop. Guess it's never too late to learn?
@BadBrad17, Yes, MPLW lets you add the additional screens and since you know how to use PS, you could make some icons to use as "jumpers" if you wanted. Then you could go back to Apex and set it up to hit the icon and jump from one page to the other.
There are many many many guides on using photoshop. Its not at all complicated to do fairly decent stuff so I would say give it a go :).
Quick question, are you guys saving/backing up any of your screens or do you just start over? If you save, what method are you using and what launcher?
I downloaded that app but I can't get it to work for some reason. It won't change them. Will have to do some more playing.
As for Photoshop, if you want to play with it Adobe just released an unrestricted use for their older CS2 suite. You can download it for free. Give it a go. There are lots of tutorials on YouTube. https://forums.androidcentral.com/e...s%2Fcs2_downloads%2Findex.html&token=VlmdIZSe
Ya this is exactly what I wanted to do but not having luck with that app. Arghh. It's probably a caching issue.
I have primarily been using Nova as it does a few more things. And the backup is better as it saves by date. I switched to Apex again for my latest screen as I thought that it was supporting the multi screen feature but it doesn't so I may go back to nova.
use widget locker. there is a wide variety of custom sliders on xda, and it lets you set an alternative wallpaper, change the grid size and place basically anything on the lock screen. hope this helps :)
jojomojo
