Nexus 6 Android OS using insane amount of data
seeffff
Android OS is using an insane amount of data and I'm not sure what's going on. Since I got the warning I switched to wifi, about 2 hours ago, since then it's used 400mb!
I'm not sure what could be causing this. The other day I tried flashing a rom but it got stuck on the roms boot animation. After that I re flashed the factory image.
Also, my phone wasn't receiving some calls so I did "Get PDP List" and switched the band to United States although I'm not sure if they would affect anything.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,303
62
48
It may still be going through a set up. But that is a high amount of data to be used. Did you reflash the stock ROM through the bootloader?
