Nexus 7 2nd gen memory vs battery age
A
AC Question
Should i buy Nexus 7 2nd gen 16gb manufactured 2013-10 or Nexus 7 2nd Gen 32gb manufactured 2014-10?
Ken G1
I'm sorry I got it backwards the one with more memory is one year older otherwise there would be no question as to which to buy for the same price . Oh yeah and I forgot to mention they are the same price.
Should i buy Nexus 7 2nd gen 16gb manufactured 2014-10 or Nexus 7 2nd Gen 32gb manufactured 2013-10?
thanks
anon8380037
5,171
Personally, if they're both new I would get the older larger one -
but if they or the 2013 32gb has been used/refurbished I would go for a newer 16gb because I know that will be enough for my tablet use, but it may not be enough for others.
Main reason being I would be concerned about future battery life on a 1 year old, and it's provenance etc.
If the 32gb is specified as end of line or 14/30 day return and refurbished maybe.
I think with a 16gb you can run an OTG cable to an inexpensive Memory Stick / Thumb drive, for movies etc.
My Samsung can.
justinedwards
