Note 20/Note 20 Ultra accessories discussion.
Did you have any luck with your Zagg replacement?
A little Berry, but sadly, not enough... I ran it for about a week and finally got frustrated and ripped it off... stuck it back on the box! It was at least, working, but sometimes would take three and four tries! Can't handle that... sorry!
So sorry the Zagg didn't work for you. With that type of performance, I would have removed it also. Depending on how many times you unlock your device in a day, it becomes quite irritating having to perform multiple attempts. I threw my ESR Tempered-Glass Screen Protectors in the trash. I didn't want to deal with return process.
It's been that type of year... :)
for those who like gaming,i would recommend the BlackShark Cooler/Cooler Pro.it actually works really well.it actually cools the entire phone.but i wouldnt recommend using it on a phone with no IP rating though.
DIY screen protector. DO NOT DO IT.
a.) SPen and Fingerprint Reader still work well?
b.) If "Yes", details on your process please? Looks pretty slick... and I'm handy with my X-Acto Knives... have several.
A) S Pen and Fingerprint scanner works. But FPS is slower. It has a thickness of 0.1mm.
B) I bought automotive clear high gloss lamination by MaxDecal(used to wrap cars). Used excess wrap as shown in photo and cut manually depending on my preference. Do not cover the front facing camera or everything will be blur xD
However i do not recommend using my method as it may scratch the screen. A safer method is measure the size of screen you want to protect and cut before applying to the phone(like a normal screen protector).
For those UAG case lovers. Amazon has them on sale. Just ordered the plyo for the one 20 ultra for $15.
$25 for the plasma
$35 for the monarch
$30 for the civilian
Happy shopping!
Update.... as of right now there's an additional $5 off coupon! Ordering another plyo for the cheaper price and returning the other
$25 for the plasma
$35 for the monarch
Happy shopping!
I'm already (and have ALWAYS, on every Note I've owned) running a Supcase Unicorn Beetle Pro in black but took a look when I read your post. I just ordered the UAG Ice Plasma just to have a less bulky case to run now and then... price was right with this sale! Thanks for posting!!! Happy Holidays!
UAG Plasma Case came this afternoon via Amazon Prime. Pretty nice - nice, rugged corners, sufficient camera protection BUT, thinner, trimmer, slimmer and much lighter than my Supcase UB Pro! An actual pleasure to hold in your hand - I actually had to re-adjust my car holder in the truck because the jaws were too loose! Anyway, I'll give it another review after using it for a while! BTW, Ice is not White like it looks in the picture, it's "clear" (like ice)!
1st NOTE: Slippery Sides! Every time I grab it to pick it up, I have to make sure my fingers get under it (or) have extra force, because the clear plastic side edges are slippery compared to the rubbery, grippy sides on the UB Pro! 12/22 - 09:30AM
IMG_20201221_145221.jpegIMG_20201221_151147.jpegIMG_20201221_151706.jpegIMG_20201221_151547.jpeg
Thanks for this info. I also use UB Pro. My Hubby sawed off the holster clip & I use the holster on my note when it's in my purse to protect the screen. I've always been interested in the Plasma but have never talked myself into trying it. I'll be interested in your opinions. :)
i got tired of buying cases now ive been rocking naked...dust off with a blower once in a while...
I could never do that.
I have a Parrot that hates my phone. She knocks it to the floor, if she gets the chance, & has a trash chattering victory strut that goes along with the show. :D
Gotta have the case.
I got the Plyo case and I'm looking it a lot. I was using the Ringke fusion-x. Here are some of the differences
1 - plyo does are a little thicker so the phone feels wide holding, but not uncomfortably big
2 - plyo lies flat on its back. In one of the photos you can see that the fortnite are slightly raised to match the depth of the camera lip. Vs the fusion whose camera lip is bigger, causing the phone to wobble on its back
3 - plyo has a fitted texture on the back to prevent finger print smudges
I am using the Whitestone done glass and no issues with the plyo case.
I'll be getting the monarch car soon. I'll update with that.
I
Manufactured in Vietnam...SD version i guess? Indonesia gets the Made in Indonesia version but its Exynos.lmaoo.
Not sure what you're talking about. It's unlocked bought direct from Samsung in the US. Model SM-N986U1
Has the Qualcomm snapdragon.
Are the left right sides of the case flat or pointed edged ?
I
gmcbride
