Note 20 Ultra 128gb Verizon - Calls don't go through???!!!
castone001
217
Ever since I got this phone last week most of the calls I try to make from my home office simply time out, otr I restart the phone and half of that time they go through. I show 4g with 3 bars.
I have WiFi calling enabled and I have strong WiFi connectivity.
I had the Note10+ before and never had this problem.
I too have issues with WiFi calling on Verizon. I've turned it off. I had the same issue on the Note 10 Plus.
Have you tried calling Verizon see any outage in your area?
How old the Sim you have?
Can try resetting network, by going settings >general management >reset>reset network
Wife and son have Note9 on VZW no issues
Sim card is new, its the one that came with phone from Samsung
Resetting the network settings now will try that :) good idea!
Wifi calling never worked right on my unlocked Note 10+ on T-Mobile. It dropped any and every call I had that lasted over 5 minutes or so. So far haven't had that issue on my 20 Ultra w/TMo firmware. Hopefully resetting network will help.
Even though your sim is new it could still be defective. The one I received with my Note 20 Ultra was scratched. I was experiencing problems so I went to my AT&T store and the rep looked at my sim and he showed me
it was scratched. He replaced it and my phone is now running great.
But I see your problem has been solved.
Damn! Problem is back. I can't call out or receive calls. I can send/receive texts and other network functions. Calling isn't working. Reset the Network settings again. no love.
Talking with VZW support but well, you all know where thats gonna go. 8 hours later and they will say reset it.
UGH!
I had an issue like this with Verizon - they removed the device from the system, then re-added it. It solved my issues - just putting it out there as a possible remedy.
Ephraim
