Note 3 Problem - 'IndexService has stopped' and screen freezing every 2 minutes
But my Note 3 is still slow even with that fast class 10 chip. I have used task manager to stop all processes, clear ram memory and then things run fast! I am running a slide show on my note 3 with music hoping that that will help with the IndexService message. It's running fine with all apps off and memory clear. I guess I need an app killer. But I don't have much of my own on yet. Just Netflix, Words with Friends, Fox News. That can't be the problem. Just what the hell is IndexService anyway?
I wonder if a factory reset would help?
This sounds like a micro sd card issue similar with the SGSIII. Which I have and had the growing pain of going through. I hope this is resolved soon for all of you having problems. I'm in the mist of selling my SGSIII, and will be buying the Note 3. If anyone stops by this thread, could you state what card manufacture, class, size etc. Especially if it's been working well with no issues. Maybe it's the 64gb size compatibility when indexing? Maybe we need to use smaller size cards? I believe indexing has something to do with reading the files on the card, taking snapshots to use when you actually open up your pictures and makes it load faster. Kind of like cookies on your computer when viewing websites. The web page loads faster when you have cookies enabled.
Palm Treo line > BlackBerry line > Samsung Galaxy S line > Samsung Galaxy Note line???
Success problem solved! :) It took the better part of 24 hours for my Galaxy Note 3 to Index Service 6 gigs (6000) of photos. It is running fine and fast and I can zoom through my photos as fast as I can flick the screen.
Word of advice, let Index Service sort your data and it all will be fine. Scary yes but you will get what you paid for. The fastest phone on the planet with 96 gigs of storage space. Note 3, your rock!
Woo hoo!
yeah i have the same issue as well,sometimes when im using it,the phone would lock up but still able to lock and unlock it but couldnt get into the home screen,it could be due to so many apps open at once
I didn't have a service index issue with my 64gb card. most of my card is Music and movies maybe 1gb of pics
Tappin From My N3
Woops the problem is back on my Note 3! After running a few hours perfectly fast the IndexService message has come back and slowed things down. Actually it stops things every 30 seconds or so. Not good at all. I might take the PNY 64 gb chip out for a while then put it back in. Reset my phone to factory defaults or reset of some kind. Any ideas on the proper reset recommended? This is my first Droid phone ever.
Jerry in Orlando
Ok I "dismounted" the SD chip from settings so I can take the chip out. The speed returned instantly though the chip is still in the phone and the phone does not show the external card cause I dismounted it electrically or software wise. It is a PNY chip. I am going to buy a sandisk chip and not class 10 maybe 8 or 6.
That's the plan Stan.
Jerry in Orlando
Jerry in Orlando
I'm using a SanDisk class 10, and it's running just fine
Tappin From My N3
Bought SanDisk 32 gb micro disk for my Note3. Loaded up 6 gigs of pictures on the chip from the computer first then put the chip in Note 3. What a beautiful thing, it counted the pics 6119 each and ran smooth and fast. Sandisk 32gb HD video chip not class 10, class not mentioned on package. Just HD video.
My Note 3 is running fine and I consider this to be my last entry on this thread.
Thanks for everyone's input.
Jerry in Orlando
Thanks for all the replies, much appreciated and quite a relief to know I'm not alone. Hoping some more info on my problem and temporary fix here might help others that are having same problems, or perhaps give some clues to others that appear to be much more 'expert' than I am.... I have a Sandisk Ultra 64GB class 10. There was no problem with the phone when it arrived new and I've had the sd card loaded in the phone with files from day one. The problems seemed to occur a few days later, and as far as I know there hadn't been a significant increase or change in files or file sizes to account for this. The problem has now stopped but I've had to remove the card and reset the phone - far from ideal, I've lost the card and having seen all of your messages I'm not convinced it won't return when the sd card does.
This is what's happened since the problem started - 1.removed the files from sd card and replaced it back in the phone, 2. the freezing & indexservice messages continued 3. I removed the sd card again and factory resetted the phone 4. problem stopped and speed is back. The card is still not in the phone and I still don't know what the cause was - I've been reluctant to put the card back in in case it causes a repeat. I shall put the card back in tonight then see if the problem returns. If it doesn't I'll start to add the files back in a bit at a time. I'll report back soon.
I have exactly this same situation. I also have the 64GB card so I am thinking that it is related to that. That card is full and 70% of that is probably pdf documents. I am thinking that it is choking while trying to index all of that data. I am quite familiar with indexers and I also suspect that there is a absolutely massive index file somewhere on the unit - most likely in primary memory. I'm interested to know what types of files you have on your card. If empty then it would seem that the indexing service has a problem with 64GB cards.
James
Hi James - my 64gb card was 50% full - mainly pictures, short videos and some pdfs. Formatted the card now, removed from phone, reset the phone, problem stopped. Now to put the card back in and see what happens. Fingers crossed! Can't face effectively losing my phone again!
I remember someone mentioning this issue in another pretty recent thread in here. Not sure if it got resolved. The OP mentioned it happening with or without the 64gb card, so I wonder how widespread the issue is?
Anything else you all have in common with your Note 3's? Processor, Card brand, carrier?
Hi - yes my problems also persisted when the card was removed, that was the strange thing. Hence I had to do a factory reset to rid the problem. A mystery! Here's to hoping problem does not return when the card does
I got a similar issue but I am using a 32GB UH1 Sandisk in my Note 3 with the same results. Battery life is terrible compared to my wife's N2. I really don't want to have to live without my SD card but I wonder if anyone has brought this up to Samsung to see if we can at least get a software fix since this is plaguing a lot of people. I will probably dismount the SD card tomorrow with a fresh charge and see if that solves anything. If so I might just buy a new SD card or reformat this one since I did take it directly from my previous phone. Come to think of it, that might be the issue. Permissions to specific files from the old phone might be hanging it up.... Guess we will have to wait and find out.
I'm have faced similar problem. I have 6th card with lots of photos. It was solved with factory reset and catch wipe.
Now unfortunately my note 3 would freeze on Samsung logo when I turn it on(it died after battery finished)
I had to do factory reset so far 4 times :( after which it would work. I tried catch clear alone but does not work it has to be factory reset.
I'm not sure if my 64G external card has anything to do with it. It worked just Fine on my S4.
Now I'm afraid from turning the phone off
Any ideas? Appreciate any help :)
Hi
Here is one solution :"IndexService" issue solved..(Quick battery drain & endless or error index process) - xda-developers
And another suggestion here : [Q] indexservice issue - Page 3 - xda-developers
The link above says :
"I too faced the same problem. After 2 days I found out that it was because of one corrupted pdf file.After I removed it everything works fine.
Update: After doing some more research I found that that indexing process is taking more time for pdf files. So if you have more number of pdf files the indexservice will take a long time to complete.
So, the solution is to either keep less number of pdf files on the device or just wait till the indexservice completes. My Note3 works like a charm after it."
Hope it helps
Update
I'm now noticing the phone would boot twice when I turn it on. This behaviour ; from previous experience; indicate the phone will probably freeze at the login in the near future which would force me to do my 5th factory reset :-(
OMG.....
I am not alone!!!!
i have buy note 3, since about 2 weeks ago.
and the "index service" issue come up the first day i transfer my photo from N2 to this new N3 gadget.
and it keeps popping up, when i go to google play, when i make some calls, or even when i did nothing.
i did not put any SD card, and purely using my internal memory
and the file i put are only 2 GB
up until now, i am already go to samsung service center to re install the N3, and it pops back on on the same day.
today i am going to samsung cervice center ... again.....
after the up coming re-installation,
i am planning to use the note 3 with no new apps install, and no file transfer for couple of days.
and see from there
from the comment above, i do have plenty of PDF file. will try to sort that one up as well.
i will post updates, in here,
and guys please post any other updates regarding this... hope this "index service" issue will pass away.
one more thing,
do you guys happen to notice that note 3 is RAM consumtion is abit too high?
my phone with no new apps, is always runs in 2GB of 2.66GB .....
when i clear the RAM memory (pressing the home botton few second and on the left corner there is an ram status etc tab) it only decrease the RAM to about 1.74GB???
meanwhile in N2, it can drain as low as 500MB
suggestion please
Found this on another site
"does what it's called: indexes all the files on your phone.
You can just kill it in settings > apps > active. Should be near the bottom, one of the com.'s. Can't remember the exact name, but if you tap it, it says indexingservise. Just hit force stop and it shuts up until you reboot."
It works! I just did it but in my haste I forgot to write down the app name - I just remember that it had an android symbol. Anyway its not Rocket Science. Just do as the guy suggested and you will come across IndexService. Just press stop!
birdsong2000
