- Feb 6, 2017
- 98,036
- 14,175
- 113
Gotcha
Yes, the problem usually happens with official pages like Samsung or carrier support pages.
Hi,you'll need a computer and Odin to flash no other way around itOk, im pretty green when it comes to phones. Never really did anythingvwith them before beside talk and text, but ive started becoming more into them. So im sorry if i sound like a *****...
First thing, i do not own o computer. Never needed one to be honest.
Ok now the fun, i have a N9600 unlocked dual sim. I use it on att network.
My last security update was july 2018 and im still running abdroid 8.1 with sansung experience 9.5
I've tried dealing with Samsung, to no avail, I've called att, they said try best buy. Best buy wont touch it since it's a international unlocked phone.
So (finally I know) how in the world do i get this stupid thing to update. The software update in the menu just says software's up to date.
AP# N9600ZHUIARGO
CP# N9600ZCUIARGO
CSC#: N9600OWOIARGO
Serial# R28KBVESQM
Much appreciated of any help.
Hi Welcome!Hello,
New to the scene and have Note 9 Update question after reading and reading and referencing Odin etc.
Bottom Line, my note is stuck on January 1 2019 OS and will not update either OTA or via smart switch.
I know nothing about Odin, sd card update etc. But used to unlock my phones years ago, so I'll figure it out.
How can I get this thing to update to a or any updated OS since the Jan 1 2019?
What are the web links to Odin or files etc?
Tmobile unlocked I bought new 2 months ago
Run through Consumer Celluar (Hey, their cheap) but seems to have the ATT version below.
Unlocked Note 9 SM-N960U
Hardware REV1.1
One UI 1.0
Android Version 9
Baseband Version N960ousqu1csa7
Security Patch Level January 1 2019
Thanks in advance for your guidance.
Hi Welcome!
Go to this website and download the firmware
Also download Odin 3.13.1 there .https://www.sammobile.com/samsung/galaxy-note-9-us/firmware/SM-N960U/TMB/
After you download the firmware extract the zip with 7z . Put those 4 files in corresponding slots in Odin
BL
AP
CP
CSC can use home CSC to save data otherwise regular CSC factory Reset
Hi Welcome!
BL
AP
CP
Hi Welcome!
BL
AP
CP
Your welcomeUpdate:
Update worked flawlessly! Super easy. Thanks for the guidance!
Hi , welcome to AC Forums! shqipeI have 2 problems with my NOTE 9 (SM-N960U) TMB
1 - Problem is : I cant conect my Note 9 with S Pen.
2 ----------- : The last Softwar update in my note 9 is N960USQS1CSD1 April 1 , 2019 . And everytime i check the Softwar for Update : Your software is up to date.
i bay this phone in USA bat now i live in ALBANIA.
The phone is UNLOCKED in ALBANIA
Can anyone help me with these problems pz
Ok thanksI emptied my GDrive as I have little spare storage and it takes a whopping 4.5GB! Fresh upload here https://drive.google.com/open?id=1KsN-T2fPOahmbO6GEdmtHubqko4lU5vN
Will be deleted on Wednesday
Ok thanks
What's exactly your build number ,model number ?Hey, all. I know that this thread is really old, but I'm having some huge issues with my Note 9. Every time I try to flash the firmware (found in the reddit post here https://www.reddit.com/r/GalaxyNote9/comments/evbpy6/n960u_android_10_download/ ), it fails. I've tried multiple times. I've used CSC and HOME_CSC, I've used different versions of Odin, I've tried reinstalling the drivers, I'm using the USB cable that came with my phone...I don't know what to try next, and I'm really scared that I screwed up my extremely expensive smart phone that I'm still paying off.
The first time that I tried it, it went into a mode that says "An error occurred while updating the device software. Use the Emergency recovery function in the Smart Switch PC Software."
That option doesn't exist. If I reboot the phone in Download mode, it goes to this screen, and Odin sees it and assigns a COM port to it. However, every time it fails. I'm not even sure where to look for a log or anything to try to figure out what happened. Can anyone help me with this?? Thank you!!
Which version odin you use ?
