foolforfood
- May 17, 2010
- 21
- 0
- 0
Still looking for ideas to improve this kernel. Got any?
Perhaps some optimizing of how images are rendered? When I look at a picture in any program it takes >30 seconds. Any possibilities here?
Why? Not to be mean or anything I just see no practical use for it. You need an android-networking-enabled cifs mount system as well. ASTRO is a free file manager which supports SMB shares without any kernel hacks.
Is this kernel undervolted at idle?
D/mtpd ( 2341): Waiting for control socket
D/SProxy_mtpd( 2280): mtpd is running after 200 msec
D/mtpd ( 2341): Received 20 arguments
I/mtpd ( 2341): Using protocol pptp
I/mtpd ( 2341): Connecting to 192.168.2.1 port 1723
I/SProxy_mtpd( 2280): got data from control socket: 20
I/mtpd ( 2341): Connection established (socket = 11)
D/mtpd ( 2341): Sending SCCRQ
D/mtpd ( 2341): Received SCCRP -> Sending OCRQ (local = 8251)
I/mtpd ( 2341): Tunnel established
D/mtpd ( 2341): Received OCRQ (remote = 0)
I/mtpd ( 2341): Session established
I/mtpd ( 2341): Creating PPPoX socket
F/mtpd ( 2341): Connect() Operation not permitted
I know nothing about kernels so sorry if I'm way off here, but what about enabling RNDIS for wired tether?
btw there is a form of rndis ..
btw remember that hiddenmenu you posted..
CDG2 Settings -> Data Setting > DUN NAI hit no (doesn't save after reboot)
now plug into windows and dial up like modem
bam wired tether
Would you consider CFS, i remember when i had my Nexus One i use to use that over BFS, i never really understood the difference, i'm sure i can google it, but for some reason to me, my battery life was even better. So are you doing only BFS? Or a branch off of the two.
what do you mean? mostly likely that is something to do with the Android system, but I can still take a look.
I have tested both extensively and the major lag buster was switching to BFS. For some reason we have an obnoxious lag with Wifi and SD Card loading/unloading activity on CFS, or whatever the standard is. I even tried that new "miracle patch" for auto scheduling using CGroups.
If you really want Xionia Kernel with CFS, here is the patch I used for BFS:
http://dl.dropbox.com/u/11516160/OptimusS/taskgroup-2.6.38-backport-2.6.32.patch
To get my kernel source up to 005:
Download an extract 004 source.
cd thunderc_kernel_2.6.32.26/
adb dump /proc/config.gz
unzip config.gz
mv config .config
To remove BFS:
wget http://dl.dropbox.com/u/11516160/OptimusS/taskgroup-2.6.38-backport-2.6.32.patch
patch --dry-run -p1 < taskgroup-2.6.38-backport-2.6.32.patch
If there are no errors, (ignore warnings about "fuzz" or "offset"), remove "--dry-run" to make it real.
patch -p1 < taskgroup-2.6.38-backport-2.6.32.patch
Update the config:
make oldconfig
Now you have 005 source without BFS.
Or just try 002![]()
Lol okay, and i really appreciate it, will just play with CFS but use yours exclusively.
Thanks for all the work.
Two questions:
- Will just installing this kernel with the stock ROM give any speed increase?
- Will installing this kernel with the stock ROM cause it to not do the OTA update to 2.3, when it's available?
Thanks
Woot!
200+ apps installed
Thunderrom 1.5 with delux build prop
LuncherPro
Xionia
Overclocked MAX 768 MIN 122
just got 1304 in quadrant
SetCPU and Juice Defender
This kernal is not laggy SetCPU is, if you turn on the 'interactive' Governor
Your phone will be super snappy while still underclocking/Overclocking to the lowest setting
Good Catch
Its snappy when you USE it
I was shocked when I turned it on it was so snappy, especially with launcher pro and the 3d app tray and switching screens
