I appreciate the help. I ended up just downloading an earlier .tar file and it seemed to work. The last one posted kept closing Odin. Whatever the case, it seems to be working now. Crisis averted...for now.
Finally made the jump!
Thanks so much DriodXcon!
super simple and easy, loving superclean 2.8!
first off,.. my thanks to Adrynalyne, DroidXcon, and StandupDad you guys have done a steller job on making my phone awsome...
that being said, does anyone know whats new in the 2.8?.. (it doesnt really matter, im going to install it anyways..) i was just wondering
OK, probably a silly question, but here goes:
I see people flashing SC 2.6 with Odin then using CWM to flash SC 2.8, but I thought you could only flash ZIP files using CWM - and all of Droid's uploads are TAR files. Am I missing something?
BTW, I already have SC 2.8 (Odin), but just wondering for future use - it would be nice to flash updates without having to use a computer every time (although, to be honest, Odin is so freaking easy!)
any good suggestions to fix high time without signal
I downloaded Super Clean version 2.8(yes wipe) off the post#1 and when i try to extract, it says it is a corrupted file. I re-downloaded 3 times and this problem persists. Is this my problem or is it the file that's uploaded?
It's sooooooooooooooooooo sad that no one answer my question ne more.....I always did thanks and did reply for the help....but....its just so sad.....
My cell radio is staying right around 50 percent on time with signal loss. I tried the airplane mode trick, but the cell radio is still reporting 50 percent time without signal
