Trying to enter clockwork recovery and have a white triangle with yellow exclamation point inside of it and android dude under the white triangle...
This is what I've done to get to this point...
Entering clockwork recovery
With the phone off press and hold Volume up+Volume down+Power button.
Samsung logo will flash twice, after the second one let go of the buttons.
This will lead you into blue recovery, with the volume keys scroll to apply sdcard:update.zip then hit the home button.
thanxs for the help with the apps not installing i have one more question how do i update to superclean 2.9.1
it works off and on when i am installing apps but i still have problems is there any way to fix it without having to clear the data all the time i can only download 1 or 2 apps before it messes up thanxs and i am going to work on putting 2.9.1 on it right now
I just wanted to thank everyone involved. My Fascinate finally feels finished and polished. The annoyance of having to choose my Exchange calendar every time I create a calendar event is gone, other issues seem cleared up as well. I went back to SC 2.8, as 2.9 was randomly rebooting, and I couldn't install the 2.9.1 patch through CWM. Scripting errors. And then I couldn't backlevel CWM. I'm good for now, though.
Has there ever been a thread this busy? Over 300 pages and climbing!
i have problems with both it started when i flashed super clean 2.9 so i went back to just the Full Stock Froyo Leak+root+Froyo Clockworkmod and it was till doing it then i did what you said about clearing the data from the market and it started working fine so i decided to go back to superclean and now it is doing what it was and now clearing the data will not work it still will not let me install apps it downloads them but after is hits 100% it will not install the app
Scripting errors when trying to flash 2.9.1? I'm guessing your cwm was orange? If so you need to go to DroidXcon's clockwork thread and flash cwm-all through ODIN:
Originally posted by Landshark:
Ahhh, through ODIN. I am now running 2.9.1 and am even slightly happier than before! Thanks Landshark!
trying to download the eb01 sc 2.9 file and everytime I try to, it stops part way through it. saying connection to server has been reset.
currently running SC 2.9.1; my local blockbuster shops are all closing down but offering a free month of unlimited blockbuster streams and dvd rental plan. Anyone know how I can get the blockbuster app back onto my VZ Fascinate to do streaming? Thanks.
