[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
I use froyo very well, but just before, my phone can't do data connection. it say check the data connection or signal. but the signal is ok, and call is fine.
It happend just before, I power off and reboot, but still has a problem.
Please help me...
Do I have to reinstall the rom again?
These are the Fascinate forums for the Fascinate phone. We can't help you with the Galaxy Tab. There is a whole forum for the Galaxy Tab located here: http://forum.androidcentral.com/samsung-galaxy-tab/ you need to check there for help.
What you mean flash with that file.
I just download file, and then how can I flash this file with odin.
I am a beginner...so please explain detail....
Thanks
did you use my odin package to put froyo on the fascinate?
wait are you having problems with the tab or the fascinate
I used odin, and flash model....accordin to the instruction of froyo update.
but still "no network connection"
Do I have to load the 2.9-EB01/EB16, EB16SC29x_DXC.tar?
I will try this and let you know....
Thanks
Thanks
Fascinate have a problem...not the tab.
Thanks
model, you meant modem
oh wait, pull down the notification bar click the data toggle, , it looks like one arrow pointing down and the other pointing up
What you mean "data off"?
and how can I data on....
Sorry bother you...
Thanks
I found...I turn on the data toggle menu.
Anyway I updated latest version of froyo. I got the 26x...but now 29x...
Thanks a lot for your help.
Now it works fine.
Now it works fine.
very welcome, sorry i should have asked you to check that first , but at least you are updated now lol
Hey folks,
Just saw this and registered. What is the best version of Froyo to download? I want the least buggiest and something that does have a proper GPS fix where it does not take 10 minutes for the GPS to start navigating.
Artisto10
