[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
I am unable to select the EC10 Kernel I cant find the option to do so in CWM RED
Did you place the EC10 file on your SD Card? If so you should in CWM RED be able to choose "install zip from sd card" option, find it install it. If it is the voodoo version enable lagfix before reboot.
it says 2.9.2 so i know it took that but there is no internal memory on my phone like it can only read my card not the phone. so everytime i turn it on it makes me set up the phone all over again.
No internal memory, classic after effect of flashing a nonvoodoo kernel over a voodoo kernel without disabling lag fix. I can't remember what to do at this point. I know DroidXcon has helped people out of this jam.
yea and i didnt freek out untell i went and tryed to disable lagfix and it was already disabled would flashing the voodoo 2.9.2 rom again and turning on lagfix work????
ok guys great news everything is still there and phone seems to be working again. other then no one to text to call at this time to test it but seems like its working again.
sweet i knew yall to help thanks i should have did that the first time but i guess i started to worry i did somthing major. Thanks again guys.
I am going to be pulling the bootanimation.zip file from Adryn's SC 2.9v to put on my themed phone... just one problem... when using Astro File Manager to rename the current boot animation file on my computer to bootanimation.zip.old, my phone says I do not have permission to do it.
Is there another file manager that will give me the permission to rename the current file on my phone (system > media > bootanimation.zip) so that I can copy another one into that folder?
Thanks!
Thanks!
I used root explorer for renaming my bootanimation, it works well
Reactions: vjoaquin
Thanks!
root explorer
Reactions: vjoaquin
My most sincere thanks to Adrynalyne for helping us have fun with our phones...Also, thanks to all of you guys for your guidance and patience... LOL
GREAT JOB!!!!!
Tiokujha
