[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
ah, no prob ...there's so many different little options and menu's and settings to choose from w/ LP ..sometimes it's hard to find your way through and/or get back to somewhere you know you've been :confused: I know I've been there
You've come along way in one night huh :) are you happy
Sent from my SCH-I500 using Tapatalk
I am very happy with it!!! Thanks to you!! Only downside is maybe ill be getting 5 hrs of sleep after playing with this little baby. its almost 1 AM here in Chicago! Next stop Vodooo although i have no idea what it does, but you know me if I can flash it in odin and it doesnt wipe data im in! lol!!!!!!! Thanks again!!!
lol no you cant flash voodoo with odin well at least i dont support it... please do alot of reading about voodoo before you go that route, please ask alot of questions, get some rest buddy
yah I wont be vodooing anytime soon I dont get clockwork at all!!!! maybe with more of your tutelage but i like where the phone is at right now! few kinks but nothing major! Im sure there will be more odin packages for me to flash in the future! Thats all I can do for now! lol I need full packages! Night thanks again!!!!
How to do a perm root on my phone?
What rom/kernal to run to have phone they way it currently is(EB01DB_DXC.tar), but would like droid 2.2 os debloated with boot animation support, be stable and still be conservative on the battery?
Does rooting delete apps and other info? If not can't a backup be done just by browsing the phone's file structure and backing up stuff that way?
Thanks for the help. Not new to modding stuff. Just the way things are done now are way different then I am use to.
Again Thanks for the help
if you used EB01DB_DXC.tar then you are already 2.2 and you are already perm rooted.... if you want boot animation and better battery life consider flashing EC10SC292x_DXC.tar that file will not wipe your data and it will give you boot animation with a kernel that is good on battery life
since you are rooted just use titanium backup and be done with it, its fast and free
Reactions: DarkAngel6698
ok Thanks for the info. Another question, if i used the SC2.9.2 that you mentioned would it wipe apps and contacts?
I asked because I plan to do this to a friends phone if all goes well.
if you use the one in the OP EC10SC292x_DXC.tar
this will only work if you are already on 2.2 (EB01) the x means it doesnt wipe data..
if you are on 2.1 you must use a wipe version otherwise you will have a force close loop
So with my phone I'll be good to go on using the one in the above post, while I would have to use the Deox'd/Debloated on my friends and then use the one above right?
yes you can use the non wipe version
well since either way they will have to lose data you can use the 2.9.2 wipe version , which i have, but have not posted yet ill probably post it in a little bit before i go to sleep
please do post that version for me and the rest of us!! :)
Again Ty for the help. May have a couple of other questions later, but for now thank you.
you are welcome,,,i will be going to sleep so as i sleep during the day but please feel free to ask, we have tons of talented knowledgeable people in the fascinate forums and im sure they can answer you . if not ill answer you in the after noon
ill post it in a bit
Ok, flashed, bootani now shows during startup, but no sound for it, and shutdown no change still works fine.
What can I do to fix it?
Sorry i didnt know sound was important i thought you just cared about animation,,,,non of the froyo kernels support start up sounds yet ...im not sure about the EC10 kernel but dropping a message on Adrynalynes thread may be a good please to start either
http://forum.androidcentral.com/ver...perclean-2-9-2-ea15-eb01-eb16-ec10-based.html
or
http://forum.androidcentral.com/ver...s-hacks/70491-real-time-too-ec10-kernels.html
selenadanelle
