[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
Yeah no issues on the phone. I did not realize that odin recognized other devices hooked to the system. The second device it recognized was my USB mouse. Thanks for the quick reply.
Process...
Dl01 odin, boot
2.9 odin, boot to recovery
Flash 2.9.2 voodoo, enable lag fix, boot (and hear lady android)
Change settings (put on silent mode or change unlock screen for example)
Reboot and settings are back to default (volume mode is back on and back to slide the screen)
Plus. I can't get it to recognize my phone when I plug it up to my computer.
try flashing a different kernel
well. Did the touchwiz 2 voodoo kernel, booted, changed settings, and rebooted. Back to default settings. So frustrating, man. Should be the correct process right? Any other torches?
I'm not sure if this has been addressed but, I recently got Froyo onto my phone perfectly. Except there is one problem. The phone won't vibrate at all. I've tried everything. Do I have to reflash the phone or what? Any help would be greatly appreciated.
i assume that you have gone to settings>sound settings to make sure vibrate is on?
Yes I have. I've tried everything. Weird thing is. It was vibrating before, but out of no where it's not working. Ive tried using a different SMS and what not. But it just won't vibrate. At all. But but the haptic feedback works
yes. hold down the power button with the screen on to bring up the phone options menu and select reboot
ive had my phone act funny all of sudden a couple times and just rebooted it and it was fine. yeah i would just reflash which ever rom you are using and be sure to wipe the caches first.
DXC,
Thanks for all your efforts here. Sorry about your brick. Hope it is resolved soon.
Thanks, I hope i get it up again soon also, even if i get the Droid Charge i want my fascinate running so i can support everyone
Thanks DroiXCon Sent you a couple of Machiatos for your strong work. I flashed the complete SC2.9.2 from your original post last night midnight pacific time and have had no difficulty. I was just getting to read through the posts here and discovered there had been a problem at one point and the file even removed. I wiped x3 and cleared the cache x3 before the Odin flash. Hopefully everything will be Ok
Crghjuygf
