[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
Wait, what steps did you take to go from Eclair to Froyo? If you did a full wipe you shouldn't have these problems. Can you lay out all the steps you took when going from Eclair to Froyo? Following the steps above should set you straight anyway, but I'm curious to see what steps you took previously to figure out where the problems came from.
Everything seems to be working perfectly now. Can't thank you enough Landshark.
I originally used DroidXCon's walkthru for froyo with EB01_DXC.tar and then played around with some various Roms and CWM. I must have been doing some of these in the wrong order or something because once i tried to mess around with themes, i ran into all sorts of problems. But all seems to be well now, and thanks again for the speedy response and help. You guys do such a great job, Android Central FTW!
Reactions: Landshark
Thanks for the guide I successfully updated to froyo! Are the kernels for overclock and stupidfast out for the fascinate 2.2?
There are no kernels from stupidfast, haven't been any for a while. You can check out Jaekar99's thread for all your kernel options, post #4
Jaekar99's Thread
You're welcome. Glad everything is running well now.
Reactions: tarichar
I've been running the first 2.2 release on my phone for a while and I've noticed my battery life is not as strong anymore and performance has been buggy. I'm looking to load the update and 2.9.2 Superclean to my phone.
To be safe (b/c I'm a noob and have had some kernals and other stuff off and on my phone that I'm not sure if they're there or not anymore) I was going to back up my apps and do the return to stock procedure first, then use odin to do the froyo with superclean flash.
Is this a good idea? Is there any another steps I need to know before reseting to stock, then flashing the eb16sc29_dxc?
Can anyone help me? I'm currently on 2.9.2 and am getting intermittent issues with Bluetooth not pairing right away to my vehicles on entry. I have to either turn off Bluetooth and switch it back on for it to work or have to reboot. And when it doesn't work, speed dials don't work either.
Welcome to Android Central. Are you talking about returning to stock DI01 or DL09? No need to. You can return to stock EB01 which is still Froyo, and still get a good, deep, cleaning to start fresh, then since you will already be on Froyo, you can use EC10SC292x_DXC.tar
I am having the same blue tooth problems connecting to my car. Any one else having problems?
Mine wasn't pairing, but it wasn't working at all, period. I think I deleted it from my car and started all over from scratch meeting it with the car and now it works fine.
Does this Full Stock Froyo Leak+root+Froyo Clockworkmod EB01_DXC.tar works just as good as the superclean (of course with all the VZW stuff in it) is it similar to the one Cory made a video about?
It is just like the one in the video by Cory. It will probably lag and be more sluggish than superclean. The current versions of Superclean were derived from the EB01 Full Stock leak, then had vzw bloat taken out, and were further cleaned to optimize performance. So the EB01 Full Leak will have all the bugs that were present which caused verizon/samsung to reject it and not release it officially.
Reactions: marteagajr75
So better off going with the 2.9.2 even if it says that it will not wipe data. Better back up my info,apps and so on. When I open winrar it will recognize the file that I need to compress/extract?
Are you already on Froyo? If not you have to use the EB16SC29_DXC.tar first. If you are already on the Stock Froyo Leak, no need to wipe. You only need to wipe data when going from one operating system to the next (Eclair to Froyo.) You already did that if you used one of DroidXcon's ODIN packages to get to Froyo. You don't open winrar, just download the EC10SC292x_DXC.tar.rar file to your computer, right click on the file after it is downloaded, and choose "extract here." Then you place the extracted EC10SC292_DXC.tar file in the PDA section of ODIN.
Before you do that though, you will need the latest cwm, and it will be easier to do it while you already have the battery out and ODIN open. Before you flash the 2.9.2 file, flash this CWM-ALL in the PDA section of ODIN. It should only take 7 seconds. Then unplug usb, close ODIN, reopen ODIN, reconnect USB while holding volume down button, and flash the 2.9.2 file in the PDA section. Put battery back in, reboot, and you're done.
Reactions: kiddoe
nettirb
