[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
Can I just flash the .tar 2.2 file over 2.1? will this wipe my phone again? its okay if it does, just wondering.
yes it is,,,,,,i am considering making a verison that wont wipe but this may cause FC issues, and im trying to avoid that and the troubleshooting involved with it
ok. Before I was corrected about unzipping the .tar.rar, I tried changing the file extension and lashing that, which failed. Now, when I am trying to flash the unzipped, ODIN is hanging up with this message:
<ID:0/007> Added!!
<ID:0/007> Odin v.3 engine (ID:7)..
<ID:0/007> File analysis..
<ID:0/007> Enter CS for MD5..
<ID:0/007> Check MD5.. Do not unplug the cable..
<ID:0/007> Please wait..
<ID:0/007> Checking MD5 finished Sucessfully..
<ID:0/007> Leave CS..
<ID:0/007> SetupConnection..
Please help, I messed up.
Hang on, got ODIN to restart and flashing EB01 stock back, then will flash SC2.2
Got it now, good to go. The flash back worked.
anyone else have dload problems from the website in the OP? I have been trying for 2 days to download the links and it keeps stopping way short of the file being downloaded.
now for my question:
I just noticed that in the stock browser there isn't an option for opening up a bookmarked page. I can add bookmarks. not sure what's up with that. I don't really like any of the other browsers.
The Bookmarks option isn't a menu option anymore. Click the button to the right of the address bar in the browser window to pull up saved bookmarks.
hmmm question
Hi im new to this flashing and ROM thing on fascinate
but my question is would this work even when my phone is completely stock? (2.1 eclair)
<ID:0/007> Added!!
Samsung at the bottom click software then download and install latest drivers
disable any anti virus you have
remove battery and leave it out throughout the entire process
Change USB ports in the back of the computer,,,,dont use remote ports like monitor
Reactions: cordoni
Welcome to Android central, and yes it will work no matter what build you are on
megaupload always works for me, thats odd, ill try to attach to the OP and ill let you know
Reactions: OHFIRE
I have tried different browsers, I have rebooted the computer, I have no idea why it won't dload. I have dloaded from there before with no issues.
First thanks to droidxcon for developing eb01.....haven't been this happy since my wedding night!:D And in true "never satisfied fashion" I have noticed my battery draining at a much faster rate. Reading about resetting battery but I can't seen to find exactly how to do this.....any help woud be appreciated.
I Bricked!
Then recovered.
I now feel like I am officially a part of the ROMing community here now. :)
Just a point of clarification because I know DroidXcon would say the same thing. He did not develop EB01. EB01 is the leaked Froyo update for our Fascinates that Verizon has not pushed out yet. Adrynalyne got his hands on the leak and devloped pretty much all the versions we all have available here. DroidXcon did a hell of a lot of work to package all the different versions into what you have in this thread to make it easy on everyone to enjoy the Froyo goodness. So everybody make sure to hit the thank button as many times as you can on any of Adrynalyne's and DroidXcon's posts.
Now for your question about the battery. You can try the methods in post #1 or post #12 of this thread:
http://forum.androidcentral.com/verizon-fascinate-rooting-roms-hacks/58334-how-battery.html
And courtesy of user MonkeyGrass we have this method which worked wonders for my battery life:
Follow the battery life thread instructions about charging to 100%, power off and keep it charging til it hits 100% again, turn it back on, charge back to 100%.
Then power off, reset battery stats, and run your battery down to 5-7% off that single charge. Plug back in, and charge back to 100% (preferably with the phone off, like overnight)
If any of the battery methods works for you let everyone know here on the forums and hit the thanks button on whosever method worked for you.
After sitting for over an hour and a half, it finally completed the download. Thanks for offering to take a look at it, I appreciate it.
Thanks for the response and correction for using the term develop.....big oops from me. Anyway, I had seen that thread for the battery and am going to follow it but I don.t know how to do the actual reset of the battery stats......i even went into recovery more but couldn't find anything. Sorry if its simple....i just have never done it.
My marketplace is still reverting back to 2.1 everytime i exit the market. Anyone have any other solutions, I tried the uninstall update thing, etc.
Is there a good way to get boot animations? I tried flashing one and it didnt go so well. Is there any good material to read up on how to do this? or is boot animations something that we cant have on sc 2.1 or 2.2?
not yet , wait about a week
No worries, we've all been there. When you first get into recovery (cwm) it should be blue unless something has changed with these new packages. Hit the volume down button once to highlight apply sdcard:update.zip and hit the home key (looks like a house), this will take you into red cwm where you will do any flashing (installing) of future ROMs, themes, etc. you download to your sd card. On the first red page, the second to last option is advanced. You could hit the volume down key to get to the bottom, but it's quicker to hit the volume up button twice. Advanced should be highlighted, but don't hit the home key, in red cwm you use the power button to make choices. Inside advanced I believe the third or fourth option down is wipe battery stats. highlight that and hit the power button. you will come to a screen where it will ask you if you are sure you want to do this, there is only one yes option-all the others are no. highlight yes and hit the power button. I don't think you get a notification letting you know it was finished. Hit the menu key (lower left of your phone) to get back to the main red cwm page. The fist option highlighted on that page should be reboot system now. Hit the power button and wait for your phone to reboot.
Reactions: Jmac9
I think boot animations will probably be slow in coming. right now the devs and everyone who has the skill level are busy trying to fix bugs and problems people are finding with EB01. I know Gunnermike53 was testing out themes in the theme thread, but I think he may be busy right now trying to purposefully find bugs and problems and brick his phone to keep the devs busy
Tfunz
