[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
Yes that is the right thread for voodoo. I believe Gunnermike53 has an explanation of what voodoo is and how it is different from non-voodoo in the thread. I am not knowledgeable when it comes to voodoo, so I couldn't tell you. As far as getting comfortable flashing you can get some practice by downloading different themes and switching back and forth between them. No need to do a wipe with flashing themes so you get practice simply navigating through cwm to install things. I like Adrynalyne's superclean ROMs, so I get plenty of practice flashing roms just trying to keep up with all the versions he puts out :p. I don't think there's anything you can do to your phone that someone here cannot help you fix. So play around and have fun.
Great, I'll do some reading up. It looks like (and I could be wrong) that Voodoo uses a different file system (EXT4) than non-voodoo.
Do you have a link to Adrynalyne's superclean roms? I'm going to start flashing themes and see what happens (other than more android addiction! ;):D)
Thanks DroidXcon & Landshark :) I think i just found Gunnermike's thread ( http://forum.androidcentral.com/ver...s/55753-how-voodoo-updated-12-feb-2011-a.html ) ...is this the same one you're referring to?
This may be a ridiculous question, but what exactly is 'voodoo' and how is it different than a non-voodoo? I'm trying as much as i can think of and exploring the threads, but i do need to get more comfortable with CWM and flashing stuff for sure. Any suggestions to build skills?:cool:
**Edit**
I did flash Chris3D's Battery Framework the other night ( http://forum.androidcentral.com/ver...ks-roms-themes-kernels-updated-2-14-11-a.html ) which works great. Made a recovery image too. So far thats all i've explored with though. I'm still looking for a theme.
You're welcom Les, and I just noticed we are from the same area, I'm in Algonquin.
I do know at least this much, you are correct about the different file system. Here is the superclean thread:
http://forum.androidcentral.com/ver...om-dl09-super-clean-0-4-eb01-2-3-updated.html
You can just click on the top of your screen where it says Verizon Fascinate Rooting,ROMs, and Hacks and that will take you back to the main page of that category. You will see a bunch of threads listed, and Adry's superclean thread is one of the stickies at the top of the list.
OK. Deleted the post with my wife's phone number (sorry Landshark - LOL) and re-posted here. Photoshop is my friend. Evidently someone didn't use spellcheck when designing this message screen:
Sent from my SCH-I500 using Tapatalk
Not too far away at all. Although I'd give anything to be somewhere warmer! And did experience all 4 seasons in one day ;)
BTW i think i just got myself hooked on flashing themes. This is too cool! :):D:):D
It is very addicting. So are these forums. So many ideas, tricks, apps being shared.
EB01SC22_DXC.tar is downloading with rar at the end of it. Odin will not find it.....anyone?
nevermind....I searched......but no luck until I looked a couple posts back.....lol!
Well the deed is done..... Well not quite yet. Still restoring Settings and apps.
Already very happy even if I had to start from scratch.
Awesome. Make sure when you do a restore through tibu you chose restore missing apps with data. and welcome to froyo and AC
Okay so the Super Clean on this is not the same as on his other page. does anyone have a working version of the first post? Also is the zip on this voodoo or non voodoo? Sorry for the noob questions.
they are non voodoo, i dont want to be part of messing up anyones phones so ill keep away from packaging voodoo.
also these are the same roms that adrynalyne provides , not like i rewrite them
what is the error you are getting
The only thing it says when I try to activate my wifi through wireless is the word error. Then it forcecloses.
* So i powered down my phone..pulled the battery out..powered it back on..and now everything on my phone works, wifi and mp3s. 11/15.
Ok so I got another question (not sure if it belongs here) In the past with my Eris i did a nandroid back up. With the Fascinate under CWM (I think phone is charging cant look at it) there was a system back up or some thing like that... but in the advanced menu there is nandroid enable/disable. What exactly am i suppose to be using for back up? Just in case i do something i dont like or not supposed to do while im "playing" with my phone!
BTW my girlfriend does not like my new hobby... i think she would perfer that i flash her instead of roms!
Don't do that, you can go to jail for that! Anyway on the first red cwm screen the 6th option is backup and restore. Click on that and you only have three options
EB01DB_DXC.tar
is the only one I can install with Odin....I really want to try SC 2.3
EB01DB_DXC.tar this is debloated not super clean you want to download
EB01SC23_DXC.tar
i compressed it with winrar
Download WINRAR
then you will be able to see the downloaded file as EB01SC23_DXC.tar.rar then right click on it and select extract here
MO Shm0
