[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
EB01DB_DXC.tar this is debloated not super clean you want to download
EB01SC23_DXC.tar
i compressed it with winrar
Download WINRAR
then you will be able to see the downloaded file as EB01SC23_DXC.tar.rar then right click on it and select extract here
Thank you I'll give it a try. I could only use the debloated one is what I was trying to say.
Don't do that, you can go to jail for that! Anyway on the first red cwm screen the 6th option is backup and restore. Click on that and you only have three options
So dont worry about the nandroid enable/disable thing in the advanced menu of the CW red?
I have not touched that, so I don't know what it does, and everything is fine with my phone
EDIT - Are you referring to enable nandroid progress and disable nanodroid progress? If so I don't know, but to me the wording sounds like it is referring to whether or not you can see the white text you see scrolling on the screen while the phone is in the process of doing a nandroid backup.
Newb here
Hi all, newbie here.
1st - much thanks to DroidXcon and Adrenalyne for their work on getting Froyo out to the forum and making it as easy as possible to update our phones. I went from nothing on my PC to using Odin to having the phone operational in under 15 minutes thanks to this forum (I'm running SC 2.1).
Now, my issue:
WiFi is not reliable.
I have WPA2 turned on for my home network. I was able to log on once, immediately after entering my password on the phone. After that - nothing. The phone couldn't even detect my network. I turned WPA2 off, changed the setting on the phone and was able to connect again. I turned WPA2 back on, and entered the password on the phone and was able to log on. After turning WiFi off and on, the phone couldn't detect the network anymore. Hopefully someone will find this info useful for troubleshooting.
I think I'll be trying to flash the newer SC versions, as well as the DB and the bloated, to see if there's any difference.
Update:
A little more info re: my WiFi issue: after re-doing the "open network" to "WPA2" steps, I find the phone can connect to my network (again) but can't get any data over the internet. I can see the phone "attached" to the router though, and my computer can access the internet over WiFi. hmmm
Also, I forgot to mention in my 1st post: other than the WiFi issue, I'm loving the SC Froyo! The launcher is much better than stock, and the phone feels so much more responsive. Keep up the good work!
the rom credit goes to adrynalyne,,,,have you tried wifi on anyone elses network or just your own?
Make sure the security protocol you use for sf wifi matches up with the protocol you have on your router. WPA can only talk to WPA, WEP to WEP, none of the protocols are backward compatable (WPA2 can't talk to WPA and vise versa)
On your PC check control panel > network & internet > manage wireless networks and see what protocol your using. I haven't hooked up to wifi yet with my sf so I'm not 100% sure how to change the security protocol.
EDIT: I just tried this and it seemed to work. Make sure your SSID is correct end you select the appropriate protocol. I experienced this prob a while ago trying to connect my mac to my home network, I selected wep instead of wpa2 and had issues. Also make sure your router is configured to accept your phones mac address. I have mine set to only accept specific devices so I had to as my phone.
Hope this helps.
Sent from my SCH-I500 using Tapatalk
First off i want to give credit where credit is due. Adrynalyne one of great advisers has brought this leak to us, he is also the one that inspired me to get this done. So thank you Adrynalyne...
Original content here: http://forum.androidcentral.com/ver...acks/59339-release-eb01-rom-kernel-radio.html
Original content here: http://forum.androidcentral.com/ver...om-dl09-super-clean-0-4-eb01-2-1-updated.html
This is my first packaged odin file so please forgive me if there is something i missed.
These packages include EB01 Kernel, Modem, recovery. It also includes root, super user application and clockwork mod for froyo all included.
THIS PACKAGE WILL WIPE YOUR DATA AND CACHE, BEFORE ATTEMPTING THIS BACKUP ANY DATA THAT IS IMPORTANT TO YOU.
AND AS ALWAYS NEITHER I NOR ANDROID CENTRAL ARE RESPONSIBLE FOR ANY HACK OR MODIFICATION YOU DO ON YOUR DEVICE.
To install
1. First you will need to download place on your sd card update.zip, download here Update.zip
2. Next you will need a Froyo tar file which will be placed in the PDA section of odin.
Download your flavor of Froyo Below
Full Stock Froyo Leak+root+Froyo Clockworkmod
EB01_DXC.tar
Debloated/Deodexed Froyo Leak+root+Froyo Clockworkmod
EB01DB_DXC.tar
Super Clean version 2.1 - EB01 Froyo leak+root+Froyo Clockworkmod
RIGHT CLICK AND SELECT EXTRACT HERE THE .rar file AFTER DOWNLOADING AND BEFORE USING -->EB01SC_DXC.tar (Does not include boot animation so be patient while it loads)
Super Clean version 2.2 - EB01 Froyo leak root+Froyo Clockworkmod
RIGHT CLICK AND SELECT EXTRACT HERE THE .rar file AFTER DOWNLOADING AND BEFORE USING -->EB01SC22_DXC.tar (Does not include boot animation so be patient while it loads)
Super Clean version 2.3 - EB01 Froyo leak root+Froyo Clockworkmod
RIGHT CLICK AND SELECT EXTRACT HERE THE .rar file AFTER DOWNLOADING AND BEFORE USING -->EB01SC23_DXC.tar (Does not include boot animation so be patient while it loads)
3. You will need to download Odin application tool found here ODIN
4.) If your phone is plugged into your computer, unplug it now.
5.) If your phone is not powered down, power it down now.
6.) Remove battery from phone.
7.) Launch ODIN on PC.
8.) Plug USB cable into phone.
9.) Press and hold the volume-down key.
10.) Plug your Fascinate into the PC via USB cable.
You should now see a gigantic yellow triangle and your phone will be in download mode. You can now release the volume key.
11.) Click on the PDA button in ODIN
Triple check that you pushed the PDA button. Do NOT click the Phone button prior to continuing to step 13. If you choose Phone, you will have bought your Fascinate a one-way ticket to hell.
12.) Choose the EB01_DXC.tar file you downloaded in step 2 above & click the Start button.(this should take approx 9mins)
13.) Phone will power down when finished.
14.) Remove USB cable.
15.) Reinsert battery.
16.) Power phone and wait to boot approx 4mins
Congrats you are done you now have Rooted Froyo with new clockwork installed if/when you need it.
NOTE DO NOT FLASH ROM MANAGER RECOVERY IT IS NOT COMPATIBLE
Tomorrow i will add trouble shooting odin and how to use clockwork for those of you who do not know....ENJOY!!!
What's difference between Super Clean version 2.1, 2.2. & 2.3 and what's the difference between them and the EB01DB_DXC.tar.md5.
EB01DB_DXC.tar.md5 is stock but missing verizion preinstalled applications
i don know the differencece between 2.1 and 2.2,,,,but 2.3 has a different lockscreen and little differences like battery icon with numeric percentages stuff like that try out 2.2 and 2.3 then decide which one you like and stick with it for awhile
Ok now if I want to install one of the sc versions do I just dl them and flash them? They are complete? The reason I ask is because the files are so much smaller. Thanks in advance.
Thanks guys for the update. I've been running 2.2 for 3 days or so and having some issues so I'll try 2.3 and see if that helps. If not, I may go back to DL09 or DJ05 for awhile.
Anyone here use the Zedge wallpaper and ringtone app? It force closes for me. All other apps work fine. I am using the Stock EB01 release.
Edit: It force closes if I go to downloads from within the app.
Can anybody confirm or deny that in EB01 you can no longer sync with exchange using the build in email app? I am not interested in using Touchdown and if this is the case it would be a deal braker for me.
Thanks for any info guys.
Mine would sync fine, but I cannot unlock it without a battery pull.
What do you mean you can not unlock without a battery pull? everytime the phone locks you have to pull the battery?
I'm running Super Clean 2.2, and Zedge works perfectly fine for me. No FC's.
Running Super Clean 2.2, I ran into a problem with text messages and Gvoice.
Happening only once in sending a message through gvoice, I didn't get a response. Ex wife, so she could be lying about not getting the message.
The bigger issue is that wife 2.0 isn't getting about half of my text messages. I can see the trail of messages, and the trail seems random on the messages her phone is not getting, or my phone isn't sending correctly. This is done through the message icon for Verizon's app.
Thoughts?
@DroidXcon,
Just curious, does superclean 2.3 include the patch which Adrynalyne mentions in his thread? See below...
Changes since 2.2:
Added LG's TodayBriefing widget and TodayScheduling widget.
Hopefully uncorrupted audio ringtones, etc. (edit: nope still has issues. Plays fine on PC though....)
Screenshot app is back due to popular demand (its only 21kb)
Hid gps crosshairs.
Added SpareParts. Phone runs nicely with animations and transiitons set to fast.
5 Lockscreen ported by sbrissen with acc battery, slightly modified by me to use ChrisDDD's acc battery icons (blue).
Latest market (2.3.2)
Patch for transitions I forgot on accident: http://adrynalyne.us/files/patches/sc_transitions.zip
bassey
