[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
I'm having some weird issues with 2.3 superclean. Followed the procedure outlined. My issues are:
-I can't get market to open. It gets stuck in *Loading.
-The Google updating icon is on continuously.
-5 minutes after booting, I start getting Force Close errors with Launcher. I seem to recall this is why I hated Launcher way back when, it never seemed to work right with the Fascinate. I'd love to get Launcher Pro on here instead.
-I had to just pull my battery and leave it off last night because something is causing it to intermittently vibrate every few seconds.
-Should my Clockwork be blue or red? Mine is blue.
Your force closes and phone vibrating are related...the phone vibrates once, then a pause and then twice when it experiences a force close.
Sounds like you have something incompatible...I'll let the experts come to your rescue because I had a similar experience to yours when I first tried this the week before and I ended up doing a completely reinstall (going back to DI01). You may not have to do that (but I don't know).
Reactions: fluidj
Anyone try to flash the 2.4 zip through CWM after flashing SC 2.3 through ODIN yet? I'm dying to hear those results so I don't have to lose any data/cache. I know DXC said that it wasn't tested, so let's test it! I can't do it until later today (around 2:30pm EST).
anything i offer is not meant to be used with cwm unless i state otherwise,,, that file is meant to be flashed with odin
if you cant wait you can use adrynalynes files here
http://forum.androidcentral.com/ver...om-dl09-super-clean-0-4-eb01-2-4-updated.html
they can be downloaded to your phone and can be flashed from clockwork
ok im going back to sleep now:p
Reactions: Inferno217
if you put the update.zip on your sdcard
from blue , scroll to apply sdcard:update.zip by pressing the home button
this should bring you into red
while in red select wipe cache partition by pressing power button
then use the search key to go back (dont ask me why makes no sense)
then reboot system with power button
if this does not fix force close,
then go for flashing DI01 MEGAUPLOAD - The leading online storage and file delivery service
make sure you boot up the phone after flashing, then you can power down
then try flashing 2.4
ok im going back to sleep for real now :confused:
ok im
Don't know what handcent is. Will investigate.
Didn't get online after I got home last night, and just got into work; already have a meeting to attend. Text issue/handcent but may end up being fruitless since I opted to go 2.3. No texts since updating to 2.3, but have a new issue (GPS) spins without locating me or says that I'm 15 miles away. 2.2 was on the money, and quick every time I used it over the couple of days it was running.
Rolling back to 2.2 and restoring is nothing but a thing. After my meeting, I'll take a look at it again.
Try updating google maps open and set it up... And turn on vzw and google location services
Ok ugh, I'm going to sleep for real now
Sent from my SCH-I500 using Tapatalk
Yeah, I ran into a similar problem, trying to go from SuperClean 2.3 to 2.4. I wound up flashing back to a virgin DI01 with Odin, booting it, then flashing the SC 2.4 Odin image onto my phone. I let that boot, then rebooted into CwM to flash the Midnight theme and clock removal fix. Then I rebooted and restored my apps/data using TiBackup.
Lots of reboots, but now it comes up fine. Now I'm trying to find info on what partition contains user data, so I can make my own custom Odin backup files. That way, I can flash one file and get back to where I was before...
How do I go from Super Clean version 2.2(non-voodoo) to 2.4? I followed the directions from this thread to get to EB01. If I want to flash voodoo kernel, what should I do? Is there any other way to solve the lag issue other than use voodoo kernel? My current fascinate will slow like 4 minutes everyday on Super Clean 2.2(non-voodoo). Thanks!
There is a separate thread in the regular Fascinate forums about Bluetooth issues...but I wanted to also post something here. Is anyone else experiencing lost bluetooth connections with built in car stereos or head units replacing car stereos? I am experiencing an issue that I can not resolve even after going back to stock and reloading EB01. Basically once a call is placed using the unit the connection freezes or something, and then the stereo and phone both report a good connection where there is none. It requires a shut down/restart of the stereo as well as turning the bluetooth off and then back on the phone.
ETA: And you know the connection got dumped because the phone responds with the tell tale "force close" vibrate sequence (one vibrate, long pause, 2 vibrates). However no force close or error message ever appears on the phone.
Reactions: Crawdad01
What kind of stereo do you have? I have sync with my car and would not flash this if I lost that connectivity!
About that, so all you are doing is setting up ODIN to flash adrynalynes files right? or are you making changes? Just wondering because it says on his post that he added boot animations and in your list in post one on this it says there aren't any. Sorry, just trying to make sure I have the most up to date.
BTW, my battery life has been absolutely dreadful with 2.3, has anybody had any better luck with 2.4?
Can anyone point me to the easiest and clearest way to go from 2.3 to the just released 2.4 that has boot animations? Do I need to go through ODIN and flash everything all over again? Or is there a faster easier way?
Thanks to all that makes this site so great and gave me the courage to make my phone better and get rid of all the BS VZW puts on there.
Ok, this was my first attempt at this whole rooting / flashing process. I choosed option #2 and it could'nt of been simpler. The only hic-up I had was in the first step with putting the update zip file on sd card (I was'nt sure what to do with it after I put it there, so I just left it there).
I thought I saved all my settings and emails but some how I screwed that up which was no big deal, just took alittle bit of time to put them back.
Not actually rooted?
I picked up Titanium Backup since I'm getting ready to flash my 3rd rom in 2 weeks (figured it was time to streamline the process). I went to launch it, & it told me that I need root access & to install busybox (which I did). Is it/could it be something I did? Can I do any damage by rooting 'over' the root that's already included in the Odin packages?
pukantu1
