[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
Hey thanks for the quick reply! For some reason im getting failed to open /sdcard/update.zip (No such file or directory). any ideas?
You have a bad or old update.zip, or it is not on the root of your sd card. Make sure you phone is in debugging mode, connect phone to pc with usb cord, pull down notification bar, click on usb connected, wait, click on gray bar that says "connect usb", when the autoplay window pops up, this is the root of your sd card. Download this:
MEGAUPLOAD - The leading online storage and file delivery service
and place it in that directory. That should work.
Reactions: droidpowered
Yeah follow land sharks directions. but makes sure to first delete any update.zip files from your download folder and your sdcard
Hi DroidXcon, Im getting it when i go into recovery. I use the volume button down to load update.zip and i come up with tha message.
Sent from my SCH-I500 using Tapatalk
When i download this zip do i place in in the sd folder? cause i didnt do that and now it seems that im stuck in recovery.
doesn't go inside any folder....select apply sdcard:update.zip by pressing the home button.......that will lead you into red clockwork screen.here you use power button to select
Ah ok im such a noob, i didnt do that in the beginning.. now i also wanted to state that i did a non voodoo superclean will this download affect me?
Nope everything i do is based off nonvoodoo
if you put nuance onto your sdcard along with update.zip ,,
once in red clockwork choose
install zip from sdcard>choose zip from sdcard>nuance.zip> once its done hit the search button to go back > then reboot
Wow I love red clockwork! You guys rock! now the only problem I have is that bluetooth still not being recognized.. again sorry for asking so many dumb questions but i think im learning a whole lot today..thats a good thing right?
for most its good, some people get to dareing lol... im not sure what the fix for the bluetooth is , hopefully landshark has an answer... sorry
I may sound like a noob but whats the difference the debloated version and the superclean versions?
Welcome to Android central :)
stock has all samsung and verizon bloatware
debloated has removed verizon bloatware and deodexed which allows you to flash themes
superclean 2.4 has removed verizon stuff / and samsung touchwiz and has custom tweaks
the rest are just there for people who want to go back and experiment with the older versions of superclean but 2.4 is most complete
Reactions: rion_j
soooper doooper awesome, thanks! im running the superclean 2.4 now and its great, just wanted to know the difference... is it possible to disable the scrolling app drawer?
how do I get to red CWM from blue?
Hey guys, Im running superclean 2.4 EB01.....
Im trying to wipe battery status in hopes of getting a longer charge to my phone. How do I get to red cwm from blue?
did you put the update.zip from step 1 on your sdcard? if you did
from blue recovery
Reactions: putney1477
lol my bad, i already flashed the rom when i asked the question then notice there was a larger debloated version and want to know the difference... i really dont like this 3d scrolling app drawer tho. im old skool.... to the left! to the left! to the right! to the right! now dip baby! lol
Excuse my lameness :)
from blue recovery
Yes, I did, thanks so much!
ADW Launcher in the market has Galaxy S-esque app drawer
from blue recovery
Anyone know the fastest way to drain. The battery dead? I just wiped battery stats...now I'm trying to kill the battery.
Put brightness to high get a run your gps in the background. And look at a completely white picture full screen so you dont get burn in....also play music in the background
phalgal
