Yes, all the Community ROM ODIN packages contain v 1.3. The TSM tab is a customizable tab you can link to any app you want. You have to go menu=>settings=>TSM Parts=>Lockscreen settings=>custom app and choose an app. After you link an app that way, the app will open whenever you slide the TSM tab.
So I ran in to my first issue his morning. I setup a few appointments in my calendar last night. To day when the alarms should have gone off. The calendar FC's on me. Any thoughts? Is there away to flash a different calendar app on to the phone?
A possible solution is to change the default notification tone associated with the calendar alarms.
If you used one of the packages in the OP of this thread, you have a debloated/deodexed/debinged version of Verizon's offcial OTA froyo release ED01. I am putting together ODIN packages for Community ROM v 1.3. I had packages completed for v 1.2 and they worked so it's just a matter of switching out the ROM and leaving everything else in the package the way it was and I should be ready to roll those out. There is also another ROM out there based off the ED01 build and that is called Evil Fascination. It should be posted in JaeKar99's Themes, ROMs, Kernels thread located here:
http://forum.androidcentral.com/ver...t-animations-combined-resource-5-10-11-a.html
Hey Landshark; just checking in with you.
How is the testing coming on your efforts for ODIN packages for Community ROM v 1.3? I looked back at your initial thread and could not tell if you had updated anything specific to the ROM and instructions for NO WIPE. Just checking in. Thanks!
ummm....might want to check the OP again. Updated 05/17 with wipe and no wipe Comm ROM packages both with the EC01 modem and without any modem.
Thank you. I was not specifically sure, and that is why I had asked. The posting seemed more focused on the voltage issues for battery - so I think that is what threw me.
Same instructions as before, just rinse and repeat as exactly provided in the instruction steps?
my phone when is not plugged in with just the usb is in it it goes to landscape mode and on occasion it also goes into car mode can someone explain why this does this
I just flashed this and everything seems to be working, I came from SC 2.4. I will have to disable screen capture though because when I push the power button it takes a pic.
I was frustrated with that also, until I downloaded Shoot Me. Free app in the market, very easy to use.
Hey guys, I just flashed the new CWM 3-30 fix and ED01DB_DOx_SHARK.tar.md5 as per the instructions on the first page of this thread. The phone rebooted just fine, but it says that I have 0.00kb of internal storage. So, I can't even dl Terminal to see if I still have root. Any help? I came over to this ROM from Super FrankenClean. Did I fail to erase something. I didn't wipe the cache or Davlic. Thanks in advance
DA
