Optimizing G4 battery thread
fast draining of battery. I have 3-4 sot with moderate usage.
- once my battery reaches 99%, it was like when im using, its draining 1% every 1-2 min
What to do to improve the battery performance?
More info is needed. Screenshots showing the top things using the battery will help use the screenshots post as reference for what to get. More advanced troubleshooting can be done using wakelock detector if after a basic overview there are still issues. Using access lock is a good way to blanket reduce wasted battery. I recommend disable keep awake permission on every app that has it and location permission for everything that location services are not critical to the apps function. But you should get those screen shots up here before doing all of that so we have a baseline.
FahadsTech
