Optimus V Support - [ROM][ZVJ][WIP] CyanogenMod 10 (Jellybean!)
Re: Optimus V Support - [ROM][ZVJ][WIP] CyanogenMod 10 (Jellybean
no problem :) sadly, however I cannot test it, as I'm currently testing BobZ rom now.
Lol, it's all good. I'm 100% sure that it works.
Just will have to wait till some other guinea pig comes along and takes a nibble. :p
Reactions: YoshinJaa
Would test but I'm on ZVJ and don't feel like getting on the laptop.
Sent from my shole using Tapatalk 2
There's no need to use a computer to flash. You can download and install straight from yyour phone. And now with my flashable zip fix, there's no real need to use ZVJ.
In theory, my fix will work for any and all Optimus S roms being used on the Optimus V, its like a 1 stop port. mms will still be broken though(can't make a flashable zip for a MMS fix AFAIK).
sent from my un-dead sammich.
I know but for me to actually test to see if it works I would have to use LGSPT to revert to ZV5 and flash it.
Ahhhh, I see now.
Any noticeable improvements using ZVJ vs. ZVD/ZV5??
Oh yeah. My service is working. I just have airplane mode on because there's bad service at work.
Sent from my LG-LS670 using Tapatalk 2
Ima noob at this I just started flashing my v I've been using tdm cm9 build picd below ,so can I use your rom on my opt v , I've been waiting for a stable jellybean rom before I went and flashed one
You can flash this rom. flash the fix that nitestalkr posted and everything will work but mms. but that can be fixed easily with go fix. but this is not really stable. it's smooth and everything, but development is still in the very early stages.
Reactions: androidCHEECH
I love the Android community seems like everybody so helpful and all workin together unlike apple where they be making you wanna put yo hands on them grrrr oh and I was reading in previous post I didnr have to get on the comp to do anything I can just download the zips on my phone and just flash from recovery or w.e the term is, true?
That is true. However, sometimes when downloading zips on the phone itll download corrupt. so make sure you nandroid backup before you go flashing.
His comment about the computer was because in earlier development of this, you had to be plugged in to a computer in order to boot the phone(sorta like having to be plugged in after jailbreaking an iphone)
Gotcha, ima give it a try right now and post screen shots after you were a awesome help bro
Did you use my flashable zip?
It contains the data fix, and the button swap fix, along with the CM10 boot animation as a bonus.
I flashed your fix again, but it didn't fix my buttons..
Anyone running this, is there anything else I need to put in the OP as far as what works / what doesn't for us?
can someone go into the market and search for youtube?? I tried but couldn't find it. I think it might be because I'm on S firmware. I went to the play store on my computer and youtube says that this app is incompatible with your sprint ls670. Anyone know how I can fix how the market sees my device to say vm670? or are other people having the same issue?
new problem, everytime I try to do usb storage for my phone to my computer, I get a notification that says you can safely remove sdcard...? I can't seem to mount my usb storage.
Waiting for others to report back on these issues, also, check the S thread and see if these are bugs they are reporting as well, or if they are specific to us, and I'll update the OP accordingly.
Greenfid28
