Optimus V Support - [ROM][ZVJ][WIP] CyanogenMod 10 (Jellybean!)
Re: Optimus V Support - [ROM][ZVJ][WIP] CyanogenMod 10 (Jellybean
+1 THIS. I would love to have automated scripts move apps to sd-ext when installed. This is moving along greatly (the fixes). Almost gives me a reason to go back to JB :)
EDIT: @Zakman: what exactly are you porting?
Still waiting on tdm to give me an answer :p
Still can't download Google Voice from the Play Store with your build.prop fixes nitestlkr :'(
Oh quick suggestion: maybe you should put versions or dates on your Jellybean fix .zips to avoid confusion and whether we have the latest one :)
Reactions: nitestalkr
Thanks for the suggestion, I will do so when I make my next fix zip. :)
And I think some aapps just are bot compatible with jelly bean yet... would make since considering this also happened soon after early early alpha ics builds were up.. just aa theory :p
sent from my un-dead sammich.
Google voice installed for me fine. There was a small time delay between nitestalkr saying the fix was available and when it actually was available....if you were like me and tried to download the second nitestalkr was online :)
this is a tentative statement and i'm not sure how to properly test this:
I think either the GPS or the WIFI stays on even when the phone goes to sleep. And the only reason I say this is because my phone died last night and my cell service was in airplane mode (i don't get cell service at my home).
how can i verify this is statement is true?
edit: actually gps is stuck at searching for service right now so maybe gps is not working?
@Zakman this build wont install on my phone, specifically here is the recovery log message:
Opening update package...
Installing update...
Installation aborted.
I've performed typical pre-flash steps i.e. wipe and format everything except sdcard.
i wasnt sure about signature verification so i tried both ways.
is there a special step i forgot to read about?
Zakman, more information. Is it built from source, ported, what?
I ported it from a p500 jb cm10 rom. I haven't tested it.
I see. Hmm well in not gonna be able to test today, but I will whenever I can tomorrow or Sunday! Btw, how did you get hydro to work on the v with the radio functions?!
redownload it
reuploading. Its a script error. i fixed it.
Reactions: sellers86
@Everyone... so, i found a flashable script similar to tdm's. but i cant seem to find a way to get it to integrate with my current fix.. But, i COULD just re-distribute the 2-ext script to be flashed on top of my patch.. thing is, installation would go like this Jellybean==>Gapps==>JellyBean super fix==>2ext script==>2ext script patch... sounds like too much flashing to me.. but that's all up to what you guys think.
to intergrate it into your fix, create a directory of system/etc/init.d and place the script in there. then look at tdms updater script to see what permissions it sets for the init.d folder, add it into your updater script, and your golden.
So I wont have tto add anything to the updater binary? That's what I was worried about lol
no, i dont think so. Ive never even been able to get an updater-binary file to open
lucky_4_honey
