Optimus V Support - [ROM][ZVJ][WIP] CyanogenMod 10 (Jellybean!)
WOAH!!!! Haven't checked this in a day and a half, and Sammyz YOU ARE A BEAST!!!!
ZVJ using s firmware hahaha that's so freaking great.
Sooo if you get this working, we can have ZVJ working on our phone, and then we can fix our data using qpst, and then flash the jelly bean, and then probably be able to fix our mms using a go fix or something like that????
What is this go fix?
Sent from my Optimus M
When I flashed this I got a warning about being grandfathered and said I needed to make a call to activate my phone. Will that make my plan rate go up? I may have download the one for the S
This rom is only for the S......
Instead of messing with the build.prop and framework.jar we usually use go sms and put in the info from the apns.conf file.
Sent from my shole using Tapatalk 2
If you could link me to that info please, that would be great :D
Re: Optimus V Support - [ROM][ZVJ][WIP] CyanogenMod 10 (Jellybean
are there any sources to this rom or is it just the rom itself?
edit:
nvm. just saw its a port not a source build.
could probably use it and swap out the kernel for the vm670's kernel build.
So it looks like I wont have time to make this guide to changing to ZVJ until tomorrow. Anyone going to port some OSZVJ roms over to OVZVJ?
Just need MMS and key switch.
edit:
The only difference that would make is the home and menu keys. Switching ril files for service doesn't boot. Already tried.
Sent from my VM670 using Tapatalk
After we get this zvj firmware, we should be able to boot cm10 and have working phone/data/sms/mms?
I really hope that you guys who just NEED to have this ROM right away enough to go through this huge process will show support for our own V developers when the time comes, by at least trying out any Jellybean ROMs that come from them. They are working very hard for us.
The type of people who are already flashing CM10 (I'm generalizing here, of course ;) ), are the type of people who would flash just about anything that gets released. I'm holding back until there's a OV ROM built from source, but you can bet I'm gonna flash the first one I can get my hands on!
Only reason im even considering doing this is only because of being able to get back to ZV5 :p
Sent from my Ainol Novo8 Advanced using Android Central Forums
WE HAVE ZVD!!!!!! I CAN CONFIRM ZVD AND WORKING ON VIRGIN NETWORK!!! I FIXED IT!!!! Im on ZV4. I replaced libgstk_exp.so, libpbmlib.so, libwms.so from His Jelly Bean Port to the same files from the ics port AND IT WORKED!!! ZVDD!
Gremlin69
