OTA_Supersonic_3.29.651.5-3.26.651.6 [official update]
Has anyone else noticed that "Custom" is no longer an option when trying to label a phone number in your contacts? Thanks in advance.
I have not noticed that, I probably should check it out. Overall, I love the update. Does wonders to the animation of swiping through home screens, apps, and 2d things. Too bad it does not improve 3d rendering but I'm satisfied
No root...
This is how I got the update and kept root...
If you have Unrevoked 3 installed:
  1. Download stock Evo Recovery image (Can't find it anywhere... EVO Stock Recovery? - xda-developers)
  2. Place the file in root of SD card and reboot into HBOOT (volume down/power button)
  3. Do the update that HBOOT asks (vol. up for YES)
  4. Reboot
  5. Once rebooted, download OTA and install (should work now)
  6. Once install finishes successfully you can reinstall a custom recovery using the same method (a list of them are here: public:forever [RootWiki])
  7. Once you have a custom recovery back, you will need to reinstall Superuser as an update.zip through recovery ([APP] Superuser 2.3.6.1 - Now on the Market [2010-09-05] - xda-developers)
  8. Reboot and enjoy!
Well I followed the instructions and the update went through... HOWEVER I have now lost root.... Help please.
EDIT: S-OFF does appear when I boot into the bootloader...
EDIT 2: This worked for me:
http://forum.xda-developers.com/showthread.php?p=8285266#post8285266
I believe I am rooted with unrevoked3 and for some reason I keep following the steps to download and put the 3.29 software upgrade, and when I do turn off and hold power button and vol down button it does a fast reboot, then it I go to recovery and it turns into a black screen with green worded choices with : reboot sys now
-usb-ms toggle
-back up resore
-flash zip
-wipe
partition
I have tried to flash sd card and and I see the updated zip I transferred over but I keep getting in the end
E:no signature (206 files)
E:verification failed
installation aborted
what am I doing wrong????
please send me and email if easier
Okay, I might be doing something wrong, I clicked the link and after it downloaded I clicked it but nothing happened. Could someone help me?
Sent from my precious Evo
And I too am having a problem. I don't know why this update just appeared for me in the last two weeks, but it has and I cannot get it to update because I'm rooted.
Am I right that all OTA updates (including gingerbread) will not work as long as I stay rooted, and in order to have wireless tether I have to be rooted?
Cuz I know just enough about all this to be dangerous, since I can't even figure out how to get this little OTA.
Seachild80
