I think you might have a totally different issue. Have you tried doing a hard reset and not install anything on it. Let is sit for atleast an hour and see if its still draining too fast. If its fine then reinstall app 1 at a time and not do a restore with data.
I have not done a hard reset. I am at work and will check the phone out late tonight when I get home. I may try and do that. Such a pita to do that though. lol But some one else made a post already about the bad battery life after the update. I literally went from 2.5 hours per 10% battery life with moderate use to a half hour per 10% not being used and just sitting on my desk.
I just unplugged the phone from re charging the battery. I will see what the phone does from now till I get home tonight. Hopefully I can figure out what the problem is. If it comes down to be doing a hard reset I will. Just sucks because I do not have any of the other issues people are having after the update. If it wasn't for the battery I would have no issues. Oh well. Just my luck. haha
