Overclockable Kernels up to 1.6 ghz and Voodoo!!!!
I'm having a hard time finding a post on the steps to remove the first lag fix... I can't get Odin to recognize my phone either and I have followed all of the steps with all of the drivers installed (Reinstalled) just incase... Still nothing!
you are putting it in bootloader (download) mode and not recovery when plugging into odin right?
(black screen with yellow graphics, says download on it somewhere)
I guess I'm confused about download mode... I enable debugging turn my phone off and pull the batt. Then plug it in and press the vol button and a yellow triangle comes up. I check Odin and my device doesn't show at all! I have the original lag fix and I'm not sure how to get rid of it, could that be causing this?
I've installed and reinstalled the drivers twice, I know they are installed because they had to be to root!
Small change to what you said above. I believe you need to press and hold the volume button before you plug it in for ODIN to see it. See if that makes any difference.
yeah i went on this thread i even replied on it:::::::
Originally Posted by adrynalyne View Post
This should not normally be needed...but in my case it was. YOU WILL LOSE ALL DATA. THIS IS NOT A TRIVIAL PROCESS.
If you need to remove Voodoo, for whatever reason (mine was not booting), this is how you do it:
1. Download original.mbr from here:
http://adrynalyne.us/files/kernels/sgs/original.mbr
2. Download stock kernel:
http://adrynalyne.us/files/kernels/sgs/stock.zip
2. Boot to cwm (battery pull, and hold up volume while putting it back in and connected to usb), and put original.mbr and stock.zip on your sdcard. Mount as mass storage or adb push them to sdcard.
3. Use adb to restore the mbr:
Code:
cat /sdcard/original.mbr > /dev/block/mmcblk0
4. Use cwm to restore the stock.zip (kernel).
5. Mount dbdata and nuke the contents.
Code:
mkdir /dbdata
Code:
mount -t rfs -o nosuid,nodev,check=no /dev/block/stl10 /dbdata
Code:
rm -f /dbdata/*.*
6. Reboot back to STOCK recovery.
Wipe data.
7. Reboot.
Done and done. Nandroid restore back after this, if you wish.
If this doesn't work, take the illogical steps of:
Flash system, kernel and PIT with Odin. Remember, only use pda and pit sections.
Wipe again.
how do you push onto sd card... how do you open adb... i tried and it does nothing, flashes a really fast list of stuff in a command prompt looking screen and closes.... how do you nuke files... ugh... i really need voodoo outttt!!!!
like cory said, hold down the Volume down button and then plug it in, it won't look like the stock recovery screen (there will be no options to do anything) and it'll say download something or another on the screen.
jr212
