P7P - Sticky scrolling issues
Thanks! I don't want to change the refresh rate or reduce the animations, it could probably also be a bug in the Facebook application, because the problem occurs only in the last month. Maybe some update of the app broke something.
When finger remains on screen, scrolling doesn't keep going. It follows your finger. It is possible the OP jgandroid thumb is touching lightly causing him to think it is a sticky scroll. Or, the screen is ultra sensitive and it detects the thumb as if it is touching. it doesn't have this issue.
It's possible can wait and see or install another version
As far as I'm concerned, the problem only occurs with Facebook. It doesn't depend on how you scroll, I've done various tests.
I noticed that the problem occurs even with Instagram, but less often.
I deduce that is a problem with Meta apps at this point, everything else works good.
dmflowsjalallodhi
