Percentage Drain Discharge when screen is off per hour typical for S6 active?
I didnt see a huge difference doing greenify to a few apps or trying the hibernation... On package disabler.. which bloatware did you disable.. some of the pink labeled bloatware are items that are needed i think.
Use disable all bloatwares from the app and enable those you need after. You can do it right after a factory reset then install your own app so won't disable something important.
Tfunz
