Pixel 6 & 6 Pro screen protectors
The Zagg tempered glass screen protectors are available. But they popped up in Australia. I saw it posted on Reddit. Sit tight.
As promised a follow up of the Mowei UV tempered glass screen protector for the 6 Pro.
Fist impressions after putting this on is that it is absolutely amazing! it feels perfect cause its glass and curves over the edges and fits perfect. I feel like I don't even have a screen protector on the device! would 100% recommend.
**The installation is a bit tricky so if you do get this I recommend watching the installation video a few times before attempting!
**Make sure you cover the top speaker grill as well as the bottom one before you proceed with installation.
Few pictures:
[SNIPPED TO SAVE SPACE]
Link to product page:
https://www.amazon.ca/Mowei-Pro-Ultrasonic-Fingerprint-transparency/dp/B09LDF5C84/ref=sr_1_8?crid=28VR0N770S5UU&keywords=mowei&qid=1640209826&sprefix=mowei%2Caps%2C137&sr=8-8
For those in USA, this is the same item, 20% less. Ordered it on 12/23, arrived this morning, just installed it.
My experience was identical to Prath09's - perfect fit. There is a very, very small edge of the side of the screen uncovered (probably 1/16" or so), but that's on the side after it has rolled off enough so you'd have to actively be inspecting for it. Not something I noticed by feel either.
After installing, I threw my phone back into my Bellroy case, and I see no way in which its appearance or feel is discernable from what they were before installation.
This also includes 3 screen protectors, so while not inexpensive, is a great value compared to the Whitestone. Time will tell if it holds up as well, or if it suffers any of the 'spiderwebbing' that plagued the Whitestone (and two of their replacements) on my Pixel 3 XL.
It does have 2 protectors for the camera array. I opted against using those, but it's worth mentioning.
EDIT: the only area of performance in which I find this product lacking is the oleophobic coating. Or, more accurately, the evident lack thereof - it holds dust and fingerprints pretty badly.
I may try applying an oleophobic spray, as otherwise the product would be a 10 /10.
I had a Zagg tempered glass screen protector installed at a mall kiosk (directly outside an Apple Store) and its the ideal fit. Once installed it is difficult to see that it's even there. I would recommend Zagg products implicitly. Unfortunately I'm not sure Zagg yet makes anything for the Pixel 6 or 6 Pro.
I have the Zagg on my regular Pixel 6... Very hit and miss with the fingerprint. I wouldn't recommend it. Returning it to BB next week.
I watched the official installation YouTube video. Interesting. I might drop the $$ and give it a try. I'm impressed by the warranty as well.
I just installed it.... Alot of steps, but pretty easy if you follow the instructions. Fingerprint so far works great (so far).
The only concern for others may be that it extends on the sides pretty good, so it may not work for some cases.
That's some money to spend and effort to only find it doesn't work with one's case. I wonder if it works with Spidgen cases.
Re: Pixel 6 & 6 Pro screen protectors
Hopefully my Dome comes soon :(
Order since Dec 17 but think shipping was going out on Dec 27th
Spigen Ultra and Ringke Fusion it fits good. Right to the edge of the case. I'm thinking the bulkier cases with the raised sides may have a problem. So far, so good, especially the fingerprint.
Odd .... Ordered mine on Christmas, got delivered by FedEx today (SoCal).
Hopefully you get it soon. It's solid, like they usually are.
Ill have to check with WSD tomorrow see what they say
Same...then saw this
Here's the Dome with a Ringke Fusion case on it. Hope you can see it.
Like I said, it's right to the case. Perfect fit for this case...PXL_20220103_145324414.jpg
Hi, got a pixel 6 over the Christmas. First thing I did was to put a tempered glass screen protector on. The finger print scanner does not work at all. Tempered glass was ok with my previous hauwei p30 pro. Now I have to use the pin unlock.
Did you set your finger prints with the glass screen protector on?
rido7788
